Old 03-08-2016, 01:22 PM   #1
Tranberg   Tranberg is offline
Air filter for Chinese underbone
Edit: Question about air filter in ths post: http://chinariders.net/showpost.php?...72&postcount=8
Hello all
Please point me in the right direction to understand the ignition system on Zongshen 125 horizontal engine with E-start.
I've bought a non-running Zongshen ZS125-47 underbone with 200km on the odometer.
The seller already replaced the CDI unit, which plugs into a 5-core cable, that ends in a gear indicator switch on the motor. ???
I bought a new ignition coil, but that didn't change anything.
All the wiring connectors are sloppy, and I plan to solder the wires instead.
When wiggling the connectors, the indicated gear lamps change between neutral, 4 and dimly 3.
Old 03-08-2016, 02:46 PM   #2
I suspect that the electrical terminals were torn out of the housings and put incorrectly together by the dreaded previous owner.
Old 03-08-2016, 04:26 PM   #3
humanbeing's Avatar
Originally Posted by Tranberg View Post
The seller already replaced the CDI unit, which plugs into a 5-core cable, that ends in a gear indicator switch on the motor. ???....
Holy CRAP!!!
AC-CDI
DC-CDI
http://www.dansmc.com/electricaltesting.htm | http://fanyi.baidu.com/transpage?que...to=en&render=1 | http://fanyi.baidu.com/transpage?que...to=en&render=1
Wiring diagram http://pan.baidu.com/s/1gdS4vWB (stolen from ISBN: 9787115143907)
Old 03-08-2016, 05:21 PM   #4
Thanks a bunch.
Meanwhile I found a picture on T-BoltUSA, where they specifically warn you that the gear indicator plug fits into the CDI socket.
It COULD be a cover-up to mask that the engine is blown after only 200 km.
Worst case, an engine is only $360, I paid $370 for the bike.
I think I will have it running by tomorrow!
EDIT: I see that the ZS125-47 wiring diagram shows a 4-wire "DC-CDI", but mine has the black/red wire from the stator like shown in diagrams for 5-wire A/C-CDI from T-BoltUSA
Old 03-08-2016, 07:33 PM   #5
humanbeing's Avatar
Horizontal chonda AC-CDi had 2 types.
smaller: 嘉陵70 (CD70 clone) | bigger: 大阳100 (C100 clone)
Old 03-09-2016, 10:35 AM   #6
I doubt that the motor is blown. It's more likely that the valves aren't set properly, and the PO didn't understand how to adjust them (or even think of it).
Old 03-09-2016, 12:10 PM   #7
It's alive!
All I had to to was to switch the connectors.
The green plug from the gear indicator goes to the beige socket of the wiring harness, and the beige plug from the motor goes to the green socket of the CDI.
It fired up, but I had to give full choke.
I plugged off the large intake spigot on the exhaust air injection thingy, which had no hose on it, and then I could adjust a decent idle.
The clutch didn't release by pressing the gear lever, so I turned out the adjustment screw until it did. What's the correct procedure? Neutral is hard to find when the clutch works, otherwise not.
I got a late start, because the guy who owns the place where I unloaded it and locked it away for the night was in a bad mood, and didn't get up before 1 PM.
Tomorrow I will get it licensed, I only have to go ½ mile and pay $125.
Old 03-10-2016, 03:35 PM   #8
Today I got it licensed so I could ride it legally. Highest recorded speed by Endomondo on my Iphone was 88 kph/55MPH
I think it's running lean at WOT, but cleaning the carb and raising the needle all the way helped a lot at intermediate throttle openings.
I closed the four ½" holes some precious owner made in the air filter box, which only contained a flat metal plate with a metal screen.
QUESTION: Where can I find a service manual for this Zongshen ZS125-47, to determine how the filter is supposed to look?
I've found the airbox on TaoBao, but what's supposed to be inside? http://sea.taobao.com/item/en/40788633962.htm
This sponge? http://sea.taobao.com/item/40818127787.htm
Old 03-10-2016, 05:22 PM   #9
humanbeing's Avatar
... Where can I find a service manual for this Zongshen ZS125-47, to determine how the filter is supposed to look?
I've found the airbox on TaoBao, but what's supposed to be inside? http://sea.taobao.com/item/en/40788633962.htm...
Closet Honda of that style (泰本田 thai Honda) sold in EU is ANF125 (carb version) https://en.wikipedia.org/wiki/Honda_Wave_series
http://www.bike-parts-honda.com/iden...t_n_chassis_2=
The Honda are supposed like http://item.taobao.com/item.htm?id=43230548371
Chinese version often use washable "foam" instead
