Old 12-04-2015, 11:44 AM   #46
Rix86   Rix86 is offline
Rix86's Avatar
Still here.
It went to cali for a couple months and survived a lay-down. He clocked it at 60 flat out. Said it didn't really want to come down out of 5th after that for a bit.....
Still need cables for it.
But just for fun I collected a couple free redcat 4wheelers.
A 150 automatic and a 200 shaft drive. Neither run. Both are in rough shape. And they were both free.
Old 12-04-2015, 12:36 PM   #47
Free is good! Pics?
Old 12-05-2015, 12:04 PM   #48
Rix86's Avatar
I'll try to get pics up.
Old 03-10-2016, 11:54 AM   #49
Rix86's Avatar
here's the red 200
The front upper and lower ball joints are shot. That's not so good. steering joints are not so hot either. Swing arm was loose (all of it), that didn't do anything any good.
Runs like a champ. (after cleaning a LOT of varnish out of the carb and jets)
Plastics are shot.
The black one (150 horizontal)
The key switch was shot.
The safety switch was shot.
The hydr rear brake master is broken, and empty.
Front brakes don't work real well.
Carb was plugged with black gooey varnish stuff.
Idles really high still, but runs good.
It has an extra vacuum line off the intake that I don't know what to do with.
And it has this hose.... it sounds like a reed valve, lik ein old air injection systems....not sure where it's supposed to go either.
I still need cables for the maxfine too.
Old 06-03-2016, 01:52 AM   #50
Cascadian   Cascadian is offline
are you still having trouble finding cables?
i recently picked up one of these bikes and these forums have been a great help figuring out what i have.
mine still had the tach cable attached, and they appear to be interchangeable, i could post pictures for you.
Old 05-29-2017, 12:06 AM   #51
Rix86's Avatar
Can't hurt.
