Originally Posted by SpudRider
CO2,
If I understand correctly, you want to eliminate the clutch safety. In other words, you want to be able to start the engine without pulling the clutch lever. Is that correct?
My model is brake's contact to start way. not clutch. if i cant pull brakes / not actived brake light, ignition not start, march motor worked but coil not i want solved that problem., this is a little secrty option, i cant need that my moto im only used.
Rx3 how start first? clutch (clutch switch?) + start button?
