10-14-2007, 01:12 AM | #1 |
250 cc kit for lifan engine
I saw a kit on here earlier from 200 cc to 250 i can't seem to find it going through the posts can anyone help me out? thanks
10-14-2007, 08:09 AM | #2 |
Nope, you didn't see that here. No such kit exists as far as I know. Never heard of it.
10-14-2007, 02:12 PM | #3 |
saw it just wish i would have put it on my favorites
It was on here not sure if it was for the lifan 200 cc engine or not but i haven't hallucinated in a long time so i'm pretty sure i saw it
10-14-2007, 06:36 PM | #4 |
Just going from 200cc to 250cc would pretty much be a waste of time and money. I think the 200cc engine would really come alive if the compession was raised to 10.5 or 11 to 1, add to that better flow (carb and exaust) and a bit of advance on the cam, I'd guess you could push 20hp or more with a good tune. Once I get my TDM in tune, I plan on executing these mods on my Lifan. The good thing about it would be the minimum outlay for parts (locate a stock 30mm carb and an ebay pipe) and the machine work would only entail either machining the head or cylinder base (and figuring out how to degree the cam, if possible).
Compression is where the power comes from. I've seen a Honda Civic SOHC turning close to 140hp on a similar setup, that's up from a stock rating of 98hp. (that's with a stock cam that had been degreed, a slightly larger TB and a good exauhst... but he did swap pistons to get around 12.3:1 compression!.) |
10-14-2007, 08:26 PM | #5 |
Pretty sure no one makes a 250 kit for China bikes... There was or is a guy from the Phillipines that was fabricating parts but they were for the Lifan 200cc street bikes...
06 Lifan 200 GY-5 |
10-14-2007, 09:29 PM | #6 |
maybe it was the street bike deal
now that i think about it
11-06-2007, 07:47 PM | #7 |
dont put too mutch compression !
i cant start my 500 cause it has way 2 mutch compression i sprained my leg lol |
