#46 |
X2.
#47 |
Thanks for the kind words. I walk the fine line between optimism and realism every day, but I learned a long time ago that pessimism never pays. In the immortal words of miss Kimberly "Sweet Brown" Wilkins - Ain't nobody got time for that !!!
I bought a chinese battery off ebay for $17, so I'm not terribly shocked or surprised that it's a dud. I'll get a new one come payday, along with a few other parts I've been putting off. Maybe now would be a good time to finally replace the cracked, road rashed, tire-rubbed, battery box that is currently held closed by several zip-ties. I can't help but notice that a slightly larger size code battery may fit in there... The headlight did not ever get any brighter, it just barely had a glow even after the trickle charger declared the battery fully charged - I still did not put a meter on it, not that it matters much at this point, I just keep forgetting to bring my meter home from work.
2004 United Motors DS200 "Denise" Be Dragonized! |
#48 |
Grabbed my meter
Resting battery voltage = 12.51 Start bike = 12.24 Rev engine to ~3000rpm = 12.27 Turn lights off(engine running) = 12.31 Turn lights back on =12.24 Turn lights and engine off =12.40 Turn lights back on (engine off) =12.23 Bike has run about 4 miles since trickle charge I think the $17 China battery is just fine, and my charging system is at fault
#49 |
Yep looks like something wrong with the charging. Hopefully just a bad connection easy fix.
#50 |
If not a bad connection, I hope it's the regulator. Cheap and easy fix.
