Old 05-20-2015, 03:00 PM   #3556
Huck369   Huck369 is offline
Huck369's Avatar
Originally Posted by rjmorel View Post
A few thingies I've added to my RX3. Home made 3D printed throttle lock, SW Motech Bags Connection Tank bag mount, had to make a mounting ring to fit the RX3 to adapt the horse shoe quick mount , Puig clip on windscreen extension which gets the bugs up out of my helmet face shield better, rj
http://www.ebay.com/itm/PUIG-CLIP-ON...item4ae45033f5
Does the clip on lip get the air up over your helmet?
If so, how tall are you?
I like your add-ons
Thanks!
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 05-20-2015, 03:34 PM   #3557
rjmorel   rjmorel is offline
rjmorel's Avatar
I like your add-ons
Thanks!
I'm around 5'6" . It brought the air flow up towards the top part of the helmet so I don't get as much wind buffeting noise and face shield stays cleaner from the bugs hitting above the helmet visor mostly . If it was 2-3" more inches taller so it was just below my vision when looking straight ahead it would probable get the flow clear over the helmet. rj
Old 05-20-2015, 04:38 PM   #3558
G19Tony   G19Tony is offline
G19Tony's Avatar
Originally Posted by SpudRider View Post
It was very easy to remove the logo badge. As you can see, the badge has two location pins, which extend through the panel. After removing the panels, I merely tapped the pins from the inside with a hammer.
To install the new badge, remove the tape covering the adhesive, and press the badge into place. Voila!
Thank you Spud.
Honda CB300R ABS
Old 05-20-2015, 09:27 PM   #3559
rjmorel's Avatar
more hor devours econo-bob style
Added some tie down points to trunk and side case for strapping on a sleeping bag, tent ,jacket ,etc. Kept them off to the side so I can mount a roto-pak gas can on top of the trunk if need be.
Found a cheap 12v/ usb handle bar mount receptical so I put that on just for the fun of it for my GPS. rj
http://www.ebay.com/itm/1-4-Pack-of-...a2a320&vxp=mtr
Old 05-20-2015, 11:06 PM   #3560
Inroads   Inroads is offline
Originally Posted by oldqwerty View Post
I prefer to spend a little extra and put RideOn in my tires. It will outperform any other sealant by fare. It is also water based and can be easily cleaned up if a patch is needed. All around, a far better product than Slime and other cheaper options, and when one rides truly remote places, the extra dollars are cheap insurance.
The new websites are A W E S O M E ! ! ! Clean, simple, and so easy to use no 12-year old necessary. Easy shopping for accessories and other things CSC sells, too.
Have you done comparisons between Slime and RideOn tire sealants ?
You say RideOn is far superior...what proof do you have ? RideOn costs twice as much as Slime so is it that much better ? Thanks.
Old 05-21-2015, 12:01 AM   #3561
I love that mod! I was planning on doing the same thing. Thanks for posting the link to the eye straps.
Old 05-21-2015, 01:20 AM   #3562
That's really cool! I'd love to play with a 3D printer.
Old 05-21-2015, 01:30 AM   #3563
X2.
Old 05-21-2015, 11:51 AM   #3564
If you are riding in remote places, it's very wise to carry a personal locator beacon (PLB). You can read my review of the ACR ResQLink PLB at the following link.
http://www.chinariders.net/showthread.php?t=14367
The ACR PLB summer rebate of $50 is now in effect until June 30, 2015. Make sure you purchase your ResQLink from a participating dealer.
https://www.acrartex.com/media/13760...w-template.pdf
Old 05-21-2015, 04:40 PM   #3565
LordRad   LordRad is offline
here are a few pics of the rally version made by the manufacturer distributing this beauty in Colombia.
this one has 21" and 19" alloy rims
according to press release, for the commercially available version, front suspension is the adjustable one used on the special edition (the gold one) and comes standard with the LED headlight.
Luggage is offered as an option. looks neat with that red saddle tho
Old 05-21-2015, 05:01 PM   #3566
oldqwerty   oldqwerty is offline
Oh, I have no proof at all. I just made that up.
Over the course of 50+ years of riding, try one product, then another, then let us know what's never let you down. Then google each product and compare the sales pitches and decide which experience has shown is hype and which is closer to true. Then being the cheapskate, use Slime anyway so you can't get a patch to fix the hole Slime won't plug, a really bad way to figure out the oil-based Slime prevents repairs, so I can wave as I go by with 7 cactus spines, 3 briar spikes, two nails, a wood screw, and a rattle snake fang (all collected on my last trip to Chihuahua Desert) in my fully inflated tires that will have the tubes patched that evening because RideOn is water based and cleans the rubber tube for an even better bond when the tube is rinsed clean and dried.
Not really well controlled scientific methodology, but yes, it's that much better. RideOn is actually free for me because the balancing effect and cooling effect makes my tires last far enough longer before wearing out the extra mileage pays for the RideOn. Even on my big truck the techs who have done the last 3 B-services have commented they have never seen such low wear rates on tires on any truck in our fleet. It's all RideOn's fault I won't have to spend $5500 on a good set of tires for a long, long, time. The tires on now are already 80k past normal wear out miles, and look like they have maybe another 120k to go. I've not had a heat/load related tire failure since installing RideOn 210,000 miles ago, and I used to have one about once a month to 6 weeks.
If you do more off road than on, the ultra heavy duty tubes provide more area for any sealant to stick to, so, unless racing, use them. For street, regular heavy duty tubes seal better than standard tubes, but the UHD tubes are not recommended for street use.
"Thou shall not Zong" is not a commandment.
Old 05-21-2015, 05:08 PM   #3567
jimjr21   jimjr21 is offline
I spy:
beefy case guard
4 spot lights
neat seat cover
Stainless steel front brake line
handguards without interior mount
nice wrap on a white bike
Currently In the garage in various states of running (or not) order
2015 Rx-3 super speedy blue
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
1952 Ariel Square four
Old 05-21-2015, 10:52 PM   #3568
Co2   Co2 is offline
Hi everyone ( from Turkey ) , my first message post, sorry my poor language and grammer, same as " Tarzan " style
Rx3 is very nice bike for my eyes^^ i hope better comfortable seat , im use a ZS177MM motor (zongshen) origin as Xmotos XZ250RM supermoto/cross or dirt bike version ,satisfied bike for me .
2011 model and i buy 0 kilometer on 2013 , 34mm dellorto carburator, and 5. gear version , power and torque is awesome for me. (but not economic, enemy of benzin/petrol 100km/liter = 5 - 6 liter if full thortle. if ride same a girl^^ 5.gear low rpm and 70-80kmh 3 liter max 100km)
İ cant use services/maintenance period(i'm make all maintenance) , and i enjoyed bit modifcations, example double radiator panel have, but need a fan , i found "regal raptor" chinese cruiser radiator fan, and i mounted it on my bike manuel swith action only^^ basic.
And this month, i think moto need "OİL COOLER" requested for me, because south turkey is in summer and very hot climate, and i think oil temperature very highly.
Ok ""tarzan"" style mesaages end , and my bike, have nice days.
Old 05-21-2015, 11:04 PM   #3569
Adjuster's Avatar
Welcome Co2!
Old 05-21-2015, 11:04 PM   #3570
Adjuster's Avatar
That Rally RX3 looks great!
