#1 | |
Wow, thanks so much for all the information. So the first thing I did was went and checked for the number you mentioned. I found two, the first one was 14-2 it was on the bottom of the cylinder, an the next one was 97mL it was on the right side of the cylinder. Heres a pic of both. http://w56i.imgup.net/KIMG0006fd4f.jpg http://v74i.imgup.net/KIMG00077765.jpg I am guessing it's a 97cc? I can't see it being 142cc, plus the dash didn't make sense to me, although I could be wrong. If it is a 97cc, I noticed like you said ATVs, Dirtbikes, etc tend to round up to the nearest cc. So when searching for parts on eBay I would just search, say "100cc dirtbike performance air filter" or something similar, right? And if I wanted to buy body parts, like plastics, or handle bars, or a new throttle would I search for PW80 stuff or try to find the right kind or my actual brand? I'll probably bring the old O-Ring or whatnot with me to make sure I get teh right one. Is there any type of like sealant I should put on before tightening it back down or just put the O-Ring on it and bolt her back on? Theres no special tool I need to tighten the spokes or anything right? I tried a few using just a pair of pliers and it seemed to work. Ill be sure to check those vids out too. I also noticed another little problem today when I rode it for a bit. Before I rode it, my chain was perfect not to tight when I was sitting on the bike and not loose when I wasnt sitting on it.(this is a quick question too, how tight should my chain be, like how much play should be in it?) I took it for a ride, and when I got back, the chain was quite a bit looser than when I left. I know that the chain tensioners were tight, and that the axle bolts were tight. The only thing I can think of is on the right side there is a rather large washer or spacer, but nothing like this on the left hand side, I took pictures which are below. Any idea what could be cause that to happen? I know I tightened up eveything really good before leaving. http://i.imgur.com/qrpBw5n.jpg http://i.imgur.com/ZpNw7rs.jpg Thanks again for all the help man, its greatly appreciated! |
