White and Green Wire Under my Seat
I have a Lifan GY-2, when I took the seat off I noticed a connector that was not connected to anything, the wires coming from the connector is a white and green wire. Would anyone know what this is for and would I need to connect this to anything to get my rear and front lights working?
Thanks ![]() I will get a photo of this connector that has the two wires Tomorrow. Any info will help big time. |
No lights and an unplugged connector under the seat sounds like a recipe.
Is every green wire a ground on that bike? |
Wires / Connectors
I have the wiring harness through my bike, the front area has the headlight wires and other wire connectors, at the back of my bike I have another set of wires/connectors for my rear light / blinkers. etc. Im just curious why there is a split off the main wiring harness in the middle of the bike under the seat and its a white wire and green wire connected to a connector. Just curious why that is there and what is it for?
Another thing is under the gas thank is another two wires, I forget what color of wires they are but I think its for the gas tank sensor telling me if its full or empty if I had it connected to an odometer/kit that lets me know how much fuel I have in the tank. Why else would there be two wires coming out of the gas tank area.. what else would those wires do? ![]() |
Please show us a pic of where the wires are. I sincerely doubt they have anything to do with fuel.
Buy a test light. You can then see if the white wire has power when the bike is running. Yes, the green wire is a ground.
