ATV Identification Help Please
I just got this ATV but can't quite figure out what brand or model is. Im trying to fix it so it would help if I knew what everything was..sorry about the pictures I can retake them tomorrow so their not so dark
And on the engine it say 169fml so I looked that up and came across a lifan 200cc engine that looks exactly the same but it says lifan on the side and mine doesn't so I'm kinda thinking maybe its some type of rip off brand or something but I'm not sure
I'm still a newbie on chines quads, but the picture is getting relatively clear after a couple months of research and wrenching...
I think you'll find that the brand name on the engine plate is only important when trying to find out who made the actual engine plate... I have 2 x 110 semi-auto quads from 2 totally different manufacturers and the engine/tranny is identical between them. Furthermore, the engines appear the same as any other semi-auto 110 I've seen on line or in store. Same goes for plastic body parts, cables, switches... Its like a handful (or more) quad manufacturers went down to a Wall Mart that only carried ATV parts, where they proceed to select the parts to fit on the frame of their choice. End result, lots of cross pollination between brands. I was asking the exact same question about my 1st quad a month n a bit ago on anther forum. I found in the grand scheme of things, the brand doesn't seem so important. One can easily find the necessary parts by looking on eBay / amazon / a few on-line china quad parts vendors. One of mine had literally every switch and accessory broken or worn out (it was only $170...) and I matched up images to find everything I needed to rebuild it without much trouble. Kelly |
That "navel" suggest it's CG pushrod family.
69mm bore isn't common in 200 (the "L"). http://www.dongya.cn/prodlist.asp?page=8&tp=4&keywords= IF needs top end REBULiD: Measure barrel height / piston / pin -- GENERIC CG200: http://item.taobao.com/item.htm?id=36115235290
Welcome!
Humanbeing has given you good info. The CG200 engine is based on the Honda CG125 architecture, and the engine brand doesn't really mean much.
Brand
this is like a JET MOTTO or PANTERRA.... as mention.... the brand does not matter... it may be a BAJA as well... they use this main style a lot... usually the headlights break off and then it is hard to get the same style without spending a lot $$... so people change them up to something else..
