#91 |
Yeah see this is where my foggieness about electricity math fails me as I don't think I'm asking right, however the things I wanted to know were indeed answered. I can run a couple of low watt LED's and expect to be within normal limits and still get good light. Sweet!
I think I'm set then on a 7" 36W lightbar, if it doesn't work I'll slap it on the tractor or golf cart and go even smaller. Thanks again guys! Jim
2008 Zongshen 200GY-A, HS163FML : Needs: Battery, Battery Box, Both clutch and brake handles, exhaust system, all plastics, gas cap, starter rewired. Her name will be Phoenix. 2007 Shineray Speedee 150, 1P57QMJ: Needs: starter rewired, exhaust connected, cleaned up, ignition switch simplified, new seat and lights, new front and back racks. There's no such thing as a free puppy or motorcycle. I think I have caught the fever from y'all. |
#92 |
Stator fan and cover replaced - need bolts for them
Ok I snagged this pic somewhere and the things I have replaced are the fan and the cover. Where does the tube that comes out of the top the cover connect to? And the second question is what size bolts hold on the fan and fan cover. (This ATV came with neither)
Thanks!! Jim
#93 |
I had to contort myself in my messy shop to remove a bolt. You owe me a beer. IPA is my preference, please.
I removed the four o'clock position bolt, and found it to be 25mm long (not counting the head), with a 6.0x1.0 thread. BTW, that is a very common fastener for many things on a China quad or dirt bike. I have a selection of bolts with that thread in several different lengths. I'm partial to stainless socket head cap screws for just about any application on my machines. The tube goes nowhere. Mine is as pictured.
#94 |
I think you can power 36 watts. Will you be running a tail light?
#95 |
That tube attaches to nothing on the buggy.
#96 | |
![]() Thanks for the measurements! I have many screws/bolts to replace. Which brings me to a possible problem on the flywheel. I purchased a Lefthand 27mm flywheel removal thing so I could examine the stator, but when I attempt to screw it in it gives me the feeling of the threads on the flywheel are stripped, even after a drop of lubricant on the threads. It's like smooth smooth smooth suddenly really tight. If I do get it to where it seems like it is threading correctly up to about 1/2" to 3/4" it just pulls straight out with little pressure. Is there any other way to get the flywheel off in the event it is stripped (before me or even by me cuz I'm a bruiser?)? Perhaps the classic 3 claw type? One step forward, two steps back! Thanks for the help though, more questions on the way. Jim
#97 |
Progress!!
Ok so the ATV has had a bunch done to it, but the only thing I have pictures of at the moment is the EPA tube removal and weld plug. Since it was a very small weld and because I think my current MIG welder is malfunctioning (or I have it setup wrong) I did this one with my Oxy-Acetylene set.
Here they are the thing to be cutoff ...the pipe showing it cutoff... and the weld plug. Thanks! Jim PS Did you notice I figured out how to put text in between the pictures? :P
2008 Zongshen 200GY-A, HS163FML : Needs: Battery, Battery Box, Both clutch and brake handles, exhaust system, all plastics, gas cap, starter rewired. Her name will be Phoenix. 2007 Shineray Speedee 150, 1P57QMJ: Needs: starter rewired, exhaust connected, cleaned up, ignition switch simplified, new seat and lights, new front and back racks. There's no such thing as a free puppy or motorcycle. I think I have caught the fever from y'all. Last edited by tankme; 09-05-2014 at 06:19 PM. |
#98 | |
Thanks! Jim
#99 | |
Assuming the threads are left hand and stripped, perhaps you can make a puller that uses the tapped holes. One idea might be to use a piece of thick plate and drill holes that allow you to bolt it to the flywheel. Find the center of the plate / crankshaft, and drill and tap a hole in the center that is similar in size to what the puller uses. Let's say for starters that you select 3/8" fine thread. Screw a 3/8" fine thread bolt into the plate, allowing it to contact the crankshaft, and figure out how to hold the plate still. This might be a good time for an impact. I hope that works for you.
#100 | |
Please show us your welder. Perhaps we can assist with setup.
#101 | |
![]() Do they come in right hand thread? I suppose at this point I need to know simply for the replacement I'll need to obtain...and after looking it up they are sub $20 thank goodness. Or if it is actually left hand thread I can chase them from the back side with the puller if I don't warp the flywheel in the process of getting it off. Either way more fun on the way! Continuing on! Jim
#102 |
I think the short answer is yes, they also come in right hand thread, but I'm not sure if they ever ended up on GY6 motors. You'll need to examine the flywheel threads to be sure.
#103 |
Okay everybody i have a 07 150cc shineray speede and it wont fire. Im only 15 and dont have enough money to take it anywhere to be fixed. I meed some info on how to order parts for it. And some help on why it wont fire
#104 |
Post pictures of the bike and engine. No spark at the plug? First thing is to check your kill switch, brake lever switch and kickstand switch to make sure they are working properly.
And you might want to start your own thread here in the forum so we can keep everything together for you. / |
#105 |
Welcome. Likely a GY6 like what is in this thread. Parts are easy and cheap to get.
Recommend you start your own thread and we will help you find the problem.
