#61 |
OK, first pic is brake glass on kickstand. Bubble is a little over half full.Second is bike standing straight. Bubble gone! Third pic is what i used to take out excess fluid. Was just like one and a half squirts into a paper towel and it was at half full. Though I didn't get a chance to take it out and test it.
#62 |
I just looked at your photographs. If you bleed the brake fluid to the proper level, you should be okay. However, I suggest you also examine the brake pads. If they are worn too low, you need to replace them.
#63 | |
#64 |
Oh and told friend what you thought it might be, and he is skeptical. So I bet him 5 dollars that will fix it. Makes sense to me. So you better be right! Haha
#65 |
ok so brakes were still dragging. back disc really hot, could smell it burning by the time i pulled in driveway. guessing i should do the bleed the brakes like thou suggested, lol. ill try that tomorrow. off to find that link again.
#66 |
size and style of handlebars?
ok looking at getting some new handlebars, like the red pro taper ones but when i select size, style. i think its 7/8ths, but what would the style be called?
oh and the brakes are still giving me problems. guy is here to take a look at now. |
#67 |
You can choose any style you like. I suggest you consider the Tusk T-10 handlebars in CR High Bend style. I have these handlebars installed on my Honda XR650L, and I like them a lot.
![]() http://www.rockymountainatvmc.com/p/...k%20handlebars ![]() You have a color choice of either black, blue, red, or silver. ![]()
#68 |
ok got that handlebar, bought pro taper grips, **any recommendations *** for hand brush guards? i been finding myself off road a lot more than i expected. and i am loving this bike!!!
oh and any ideas on the brakes? drained some out, no luck. bled line, no luck… my friend doesn't know, but i would think they are set too tight? like i need to adjust them? my friend just thinks the pads were too big. that i just need to wear them down. which I'm pretty sure he told me not to drive it when it gets warm, so not sure what to do. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 these are the hand guards i ordered, universal should work I'm thinking?? Last edited by footer; 08-18-2014 at 09:39 PM. |
#69 |
Those hand guards should work.
![]() ![]() If the brake pads are too large, you could remove them and grind them down a little with either a dremel tool, or an angle grinder. If this succeeds, I would certainly try to get slimmer brakes pads in the future. ![]()
#70 |
If you choose to grind the brake pads, please wear a dust mask. Also, just chamfer the leading edges of the pad a little, not the pad face.
#71 |
Yes, do wear a dust mask, and grind slowly.
![]() Weld, if he is going to reduce the width of the brake pads, he will need to grind the entire brake pad, including the pad face. ![]() If his friend is correct, and the brake pads are too thick, he shouldn't need to remove too much material before he notices an improvement. ![]() ![]() Weld, what do you think is causing the problem? ![]()
#72 |
I'm not sure, but I'm wondering about the MC and the caliper. Parts are cheap enough that they could be replaced on spec.
#73 |
Owning a Zong, I'm much less familiar with the Hondoid parts. I imagine the rear brake parts are generic Chinese.
#74 |
Yeah we really haven't gotten into the brakes yet, but tonight or tomorrow going to check into it a bit more. Thing is they are free when the bike is off, when ridingi think its after I use the brakes they stick. Not positive on that but seems like it to me.
I'm putting the handlebars on right now. The original bars had a whole on the bottom where a slot in the turn signal slips into. The new bars don't have a hole, but I could drill one if its important. Or I could just bend the tab up so the mount sits flush. How important is it? |
#75 |
I have encountered that situation several times when changing handlebars on my motorcycles.
