Old 07-08-2014, 10:56 PM   #1
seano   seano is offline
'04 flywing mx 150 help with wiring!
Just picked up a 2004 flywing mx 150. I paid almost nothing for it.
The only real problem i am having is with the wiring. It was all cut up.
So here is what i have,
Coming from the engine, there are 6 wires.
Green with white stripe,
Black with red stripe,
Pink,
Blue,
And a yellow.
And i have a cdi box with a 2 pin and a 4 pin connector.
What wire is what? Any help, pictures or diagrams of this specific model would be great.
Old 07-09-2014, 12:59 AM   #2
humanbeing's Avatar
Std Honda color?
Bl/R EXT
P & Y AC out/ ie. to rectifier
Use multi meter find out the truth 1st, used bike might wired differently.
The "ancestor" is wired as:
Old 07-09-2014, 02:38 PM   #3
Wow thank you. This helps a little. Wish i could read chinese.
Old 07-11-2014, 03:37 AM   #4
humanbeing's Avatar
The later model (kick + electric start):
http://josemaco.files.wordpress.com/...h-62ktjam5.pdf
Old 07-12-2014, 11:51 AM   #5
I cant download that file for some reason. How do i pull the flywheel to access the stator? Must i have a puller? Or can i just remove the nut and tap it off?
Old 07-12-2014, 12:03 PM   #6
After 9 tries i was able to download.
Old 08-29-2020, 04:42 PM   #7
egomaniac   egomaniac is offline
Flywing Stator Replacement
Yes, you will need a puller to remove the Flywheel. I used a 6" puller. Mine was rusted on, so it almost broke getting it off. Finding the replacement stator was nearly impossible. I got it from China. I bought extra if you need/want to buy one. Good luck. My wiring is still flaky on the rest of it. Getting intermittent spark now. Thank you for the wiring diagrams!
Old 08-29-2020, 05:40 PM   #8
Bruces   Bruces is online now
Dude ,6 year old posts you are replying to .
