Old 12-14-2013, 03:57 AM   #16
zingshoen   zingshoen is offline
zingshoen's Avatar
she s not looking bad at all, mate! good work!
the carbie looks like a keihin copy but i may be wrong. what sort and size of main jet do you have?
does an oil breather fit below the carbie and the crankcase venthole? that would look neat.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 12-14-2013, 04:27 AM   #17
stellio78   stellio78 is offline
stellio78's Avatar
Don't know what size the standard jets are, I've just adjusted the idle fuel mixture and it seems to be running fine for short trips are my area.
I've got a small filter that I'll try and fit up for the crankcase breather soon
Old 12-14-2013, 04:35 AM   #18
zingshoen's Avatar
with that air filter you ll probably run lean at full throttle
Old 12-14-2013, 05:45 AM   #19
stellio78's Avatar
Good to know, thanks.
Jets will be looked at in the near future.
Old 12-14-2013, 06:46 AM   #20
zingshoen's Avatar
lifting the needle one notch, ie moving the needleclip one down does make a difference, if you haven t done that.
Old 12-18-2013, 03:32 AM   #21
stellio78's Avatar
Tidied up those electrics and got some nicer photos after a ride.
Old 12-18-2013, 03:33 AM   #22
stellio78's Avatar
Anyone know what the intake & exhaust valve clearance are suppose to be set to?
Old 12-18-2013, 03:43 AM   #23
Your bike looks great! I especially like the dashboard.
You might find the valve lash information you seek in the following thread.
http://www.chinariders.net/showthread.php?t=977
Old 12-18-2013, 05:41 AM   #24
humanbeing's Avatar
That's a MD33 clone.
authorized Honda dealer in Japan http://www.ride-inc.net/file/32/data.pdf
Old 12-18-2013, 10:23 AM   #25
Thanks for the confirmation, HB. I found SL230 stuff on Taobao, and I presumed it is the same motor.
Old 12-18-2013, 10:26 AM   #26
That is a sweet looking little bike. If you're looking for more power, there's some hiding in that catalytic converter. Removing it would require larger jets.
Old 12-18-2013, 02:28 PM   #27
stellio78's Avatar
Thanks HB, I'll try and work it out from the link.
Old 12-18-2013, 02:39 PM   #28
stellio78's Avatar
Weld, my idea is to make a stainless steel header pipe and buy one of those ebay carbs so jets are easier to come by.
Old 12-18-2013, 05:50 PM   #29
zingshoen's Avatar
stellio, i ve looked it up for my 233 engine before:
OHC motor, no pushrods.
According to Honda dealer in Japan http://www.ride-inc.net/file/32/data.pdf
MD33 (65.5mm x 66.2 mm) IN/EX = 0.1mm (0.004 inches)
small problem was that the flywheel didn t have a TDC marking on it. maybe yours does have one. of course one can judge from the piston. but i eventually took the left case off, and made a marking for TDC on the flywheel.
Old 12-18-2013, 08:45 PM   #30
stellio78's Avatar
Thanks mate.
