Old 07-30-2007, 11:02 AM   #1
jpasterjak   jpasterjak is offline
Replacement wheel
Hey gang...
The 19" steel front wheel on my Roketa (Xiongtai, Zongshen, whatever) DB-36 is starting to get pretty dinged from use. Lots of exposed roots where I ride. I'd like to upgrade to something a little nicer and more durable than steel. Anyone have any recommendations? I believe it's a 19 x 2.15 (at least, the measurement of the outside edges of the rim is 2.15—is this where you measure on a bike wheel?) with 36 spokes. Chapparral lists this size as a rear size for a Kawi KX125 here:
http://www.chaparral-racing.com/Chap...=False&GiftID=
Anyone replaced their rims with something better? Is this indeed a 19 x 2.15, or am I measuring wrong? Thoughts? Ideas?
Thanks
jg
Old 07-30-2007, 11:11 AM   #2
John22j   John22j is offline
You will probably be better with something like a KX100 -- it has the 19" front / 16" rear setup.
Other super-mini's (or big-wheel mini's) use this size as well.
'20 RPS Magician 250
'06 Hensim (Tierra) DB150-2
'06 X-Treme 70cc pitbike
'02 Kawasaki KX125
Old 07-30-2007, 02:09 PM   #3
katoranger's Avatar
I think the proper way to measure may be measuring the inside of the rim where the bead of the tire sits. It may be closer to 2 inches.
XR100 hondas use a 19" front wheel too. I think the ttr125 does too.
Most of the smaller 4strokes in the 100-150 range use the 19"/16" wheel sizes.
Allen
