09-29-2013, 03:28 AM | #1 |
125cc ATV
Just received 125cc ATV for my boy, took about one week for delivery. Well wrapped and in good condition. Spent half day to assemble the four wheels and other parts, run good. I have a question. I'm 180 lbs if it will break after I ride it for miles? BTW, the customer service Robert helped much. http://www.megamotormadness.com/prod...v002-110cc-atv
09-29-2013, 04:49 PM | #2 |
I would work my mileage up little by little if I was you. I don't think, once rhe bike is worked in, that it would have problems hauling you around as long as you keep in mind it is not a Honda, Suzuki, Kawi, Yamaha, etc.
You didn't mention it, but if you haven't, and hopefully before you started her up, you changed the oil, and then after 100 miles or slightly less, again. By a few hundred miles, you probably should have changed the oil 3 or 4 times.
01-23-2014, 11:38 AM | #3 |
Thanks for the report :-)
It will haul you around fine BUT if it's a CVT will be very limited in ability to climb. The same CVT though will prevent any overloading of the motor with you on it. Have fun! I bought a 90cc HSUN ATV for my stepson years ago. I weight about 175 and rode that thing a lot. It was fun and the machine did not mind at all.
Happy to serve. |
