Old 07-24-2007, 08:42 PM   #1
TeamCheap   TeamCheap is offline
I'm going to need some main jets over here PICS & SOUND
I got an exhaust coming and I'm sure it will require a rejet soooo my question is : where to get them? what sizes to get (I'll have to look at the installed one I guess)?
Old 07-24-2007, 09:17 PM   #2
ob1   ob1 is offline
http://www.sudco.com/
As for which and what size, someone else will have to chip in!
Old 07-24-2007, 09:42 PM   #3
msRandi   msRandi is offline
Send a message via AIM to msRandi
still working that out. With the K&N and and the modafided stock muffler I'm runing a 110 and I am going to try 112.5 and see if thats better or not. but I would get a hand full. starting at 105, 110, 112.5, 115. to start with. I did Denis Kerk and the jets were about 2 bucks each. good luck
Love from the Arizona High Desert
Old 07-24-2007, 10:19 PM   #4
IronFist   IronFist is offline
I have a pz27 carb that came with a 106 stock. It's only a 150 cc. I'm using a 110 now. The 106 will be too small for your 200cc. But it's yours if you think you can use it.
Too bad I had a 112 in my hand, but I gave it back to the mechanic at my local shop. He gave me the 110 and 112 to try. You should be able to pick up a 112 pretty easy at your local shop. Dirt Cheap I think MsRandi is correct get a few. N2r.
Old 07-25-2007, 05:31 AM   #5
Yeah I plan to get a few sizes(4 or 5).I will go out today and pull the carb and have a look at the jet that is in there right now and see what sizes I will need.
I have gone about as far as I can go stock since I put the K&N filter on but now with an exhaust coming for it I know I'll need the jets.
I dont know if the exhuast I bought will be any good or even fit for that matter but it is a xr200 JETSON exhaust.
Here is the pic from the Fleabay auction I bought it from.
it looks shiny if nothing else
Old 07-25-2007, 08:36 AM   #6
fatboy250   fatboy250 is offline
Nice looking pipe. Keep us posted as to whether it is a direct bolt on. If so I can put it in the parts thread.
Jason
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
1995 Kawasaki Concours (ZG1000)
Old 07-25-2007, 11:39 AM   #7
katoranger's Avatar
Saw them. We need to know about the fit. Is it stamped USFS approved?
Allen
Old 07-25-2007, 04:47 PM   #8
I'll give a report once I actually get it and put it on but I'm thinking the only two fitment problems might be the pipe size and the hanger bracket and the bracket can be remade.
Dont know if it's stamped USFS approved and from the excellent pics they posted of it I seen nothing, so that might be a small problem.They say it has a spark arrestor but dont say it is USFS approved.
JETSON-RACEHIGH enhanced sonic evacuation provides for higher flow and increased power.
I'm hoping this pipe will double no triple no wait quadruple my HP
Actually I just want to see if it could help wake this motor up a bit.
Old 07-25-2007, 05:27 PM   #9
AZ200cc   AZ200cc is offline
Careful, These bikes are pretty sporty right out of the box ...Add to many horses and it will be a suicide machine
I like that exhaust 8) So Shiny .....Wonder how it's going to sound.
<br />2001 Suzuki DR200SE<br />1997 Suzuki RM250 YIKES<br />1995 Yamaha Breeze 125 daughters<br />1991 Honda XR80r Restored<br />maybe a 2003 Yamaha TTR90
Old 07-25-2007, 11:56 PM   #10
I really like shiny bike parts. I'm envious/ 8)
Old 07-26-2007, 05:05 AM   #11
I'm thinking with that high tech futuristic pipe installed I may just have to take it down to milan "dragstrip" and show some people whats what.
If its NOT USFS approved I'll have to find a spark arrestor for it I guess since the DNR does check people/vehicles out on the trails at times.
Old 07-26-2007, 02:12 PM   #12
Please let us know what jet you end up runing.
Old 07-26-2007, 02:18 PM   #13
pacman   pacman is offline
I have a Loncin 200. I went from a 109 jet to a 116 and then to a 124. Every step gave noticable step up in power.
I use a conical sports filter . Exhausts are unmoddified.
I think the jets on these bikes are undersized, probably to give better milage.
Old 07-26-2007, 04:34 PM   #14
I'll give a report, it looks like from the shipping/tracking that it will be here monday.
Old 07-30-2007, 05:26 PM   #15
Um well yeah I did get the pipe today and it does fit the bike but I'd have to recommend against it.
Didnt see any "USFS approved" stamp on it anywhere.(expected-not to worried)
Worse than that the pipe they supply and the muffler doesn't fit very well at all.I had to get my die grinder out with some sandpaper and ream the inside of the muffler and file/sand the supplied pipe down to make it fit.
The other end is a little big so I'm off to find some stuffing for that.
Ok I do like that it is a straight shot thru the muffler (yes I can see right thru it)
Lastly, even though I dont have it clamped/sealed tightly to the exhaust pipe yet I started it up and it sounds AWESOME.It just leaks a little around the exhuast pipe and they're supplied pipe clamp but I can fix that In fact the stock pipe has a gasket at the same spot but was not useable on the new pipe.
