Old 06-28-2013, 02:20 AM   #16
Originally Posted by MICRider View Post
If I ever make it down to your neck of the woods you can take mine for a blast!
I'll take you up on that! I'd be staying two blocks from that new Target.
Old 06-28-2013, 02:24 AM   #17
I like your Son of Recracer reference.
I figured that if I ever got ahold of a GL1200, I'd mount an external alternator as well. What type did you use? It looks like a Denso.
Old 06-28-2013, 07:06 AM   #18
recracer   recracer is offline
recracer's Avatar
It is denso . I was talking to a friend of mine (lives in florida ) he said he had a little alternator on the circle track race engine sitting in his garage . He boxed it up and sent it, best price free. I really wanted a 3 ribbed belt ,but finding a combo I would be happy with proved difficult .I wanted it overdriven ,the poorboy kit at the time had the same size pulley's engine and alternator . Engine pulley sourced from ebay ,no idea of the application. even overdriven voltage can fall below charging rate below 1100 rpms . Above that it will happily charge above 13 to 14.2 volts.
Old 06-28-2013, 09:42 AM   #19
bogieboy's Avatar
Originally Posted by FastDoc View Post
120+ MPH couch :-)
Im too chicken to do that speed on 2 wheels...thats why i got a dual sport...LOL i would kill myself on anything faster....LOL i keep the speeding to in my truck, where theres at peast a chance of walkig away from a 120mph crash LOL
Old 06-28-2013, 11:11 AM   #20
That is my favourite price.
Did you do any math to arrive at the overdriven ratio? Perhaps you could get the alternator to wake up at a lower rpm. At what rpm does the bike idle?
Old 06-28-2013, 04:42 PM   #21
recracer's Avatar
I really Did not put any math to it. Those useing the poorboy kit had similar results . It was way back i did this install ,somewhere in the back of my head the crank pulley is just over 2 times the alternator pulley dia. 5-5 1/4 inches . On a car the crank pulley would likely be at least 7 inches . but there are space restaints on the bike ,the bigger the crank pulley the more you would have to move the radiator at the bottom . i am a bit futher out than the poorboy kit . i will have to check again ,i just remembered the factory volt gauge reads low compared to a meter . 1000rpm +-100 specs. I have it set at 1200 . After i check at the battery maybe i can lower it .
Old 07-01-2013, 11:50 AM   #22
recracer's Avatar
I checked it is fine at the battery . Interesting thing owner's manual says if the volt gauge drops below 10v check for a problem .
Old 07-02-2013, 11:18 AM   #23
What does the alternator put out at 1200 rpm? Do you have to rev the motor to excite the alternator?
Old 07-02-2013, 09:50 PM   #24
recracer's Avatar
Weld i don't have to rev it up ,charging seems to start right away . But also a cold start ,it may idle at 1800 or 1900 and tapers as it warms up.(love that fuel injection) I am going to put up pictures to show rpm and bike gauge and multimeter charge rates . Seems it charges enough to maintain the battery ,of course these pictures are with all the lights on . The wing does not give you a choice ,all the lights burn when its on or running. I am not super concerned about the idle charge if it dips a bit . I found out over the weekend ,if i am out on a ride with the wing ,i may see 1% idle time 99% rolling. That said , i still may replace everything i can with LED bulbs.
Old 07-02-2013, 10:00 PM   #25
recracer's Avatar
Other Features of the limited . The alternator is wired one 8Ga wire straight to a 50amp breaker on the battery . Also the grandchildren .
Old 07-03-2013, 08:15 AM   #26
cheesy   cheesy is online now
cheesy's Avatar
So many cool toys.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 07-03-2013, 10:52 AM   #27
It looks like you've got a winner. It definitely doesn't wake up until 1200rpm, but you won't idle much, just as you say.
Beautiful grandkids! I bet they love riding on the 'Wing.
Old 07-12-2013, 05:49 PM   #28
recracer's Avatar
Thumbs Up
I am getting better at the Stopping and getting feet down and a bit more comfortable working with the weight . The more I ride it the better I like It . Well loving it really .
Old 07-12-2013, 09:24 PM   #29
I am impressed by your bike, and your mechanical abilities, and your thrift.
Heck, ONLY 800 lbs???
Try an 1850cc Six cylinder. With the tank full it's 900. Put Linda and I on it and fill the saddlebags with her beauty supply products for a weekend away and we are up to 1,300 lbs.
Bike is STILL fast!
Old 07-15-2013, 02:09 PM   #30
recracer's Avatar
Hehe
Thats a bit of a load , i can see how you can get there in a hurry . I had not thought about it , but a full tank and just me would be hauling about 1000lbs and haul it will A few pictures from the weekend
