#16 |
Thank you, Pliskin.
![]() ![]() ![]() Spud ![]()
#17 |
How difficult will it be to get this one licensed as street legal?
#18 |
Licensing a dirt bike is virtually impossible in some states. :( However, making a dirt bike street-legal is very easy in Idaho.
![]() ![]() ![]() In Idaho, all you need is a headlight, tail light, brake light, horn, and a single mirror. You can mount a clown horn, if you like. ![]() ![]() ![]() Spud ![]()
#19 |
We are blessed to be able to D/S a dirtbike here in WA also, but we have the added step of needing an inspection. But a licensed mechanic can do the inspection, and my buddy Andy just signs off in exchange for a flying lesson, which I would do for him anyways.
![]() Then there is a fee or two, a tax, but as long as I leave the DMV with a plate I'm happy. :P
Happy to serve. |
#20 |
BTW the OEM horn on my (ex) BSA 441 Victor ws a horn just like in Spud's picture. 8)
Happy to serve. |
#21 |
I went for a ride on Saturday, so I took a few photographs of my license plate bracket.
![]() ![]() ![]() ![]() This bracket is very strong, and very lightweight. ![]() ![]() ![]() Spud ![]()
#22 |
I hope that lasts for you, Spud. I've found that plate holders that only support the top of the plate tend to produce cracks around the bolts holes in the aluminum. I resolved that with stainless fender washers for now, but I intend to weld a spine to the back of my stainless bracket to fully support the plate.
#23 | |
![]() Spud ![]()
#24 |
wouldn't hurt to add a short chain leash attached to fender and to the bottom of the plate incase the bracket breaks. Then you will hear it baging around BUT not lose your plate.
8" of thin light chain, 2 bolts, nuts and some washers.
TCCK: The Coca-Cola Kid......... Hide your pepsi or I take your soul !! ![]() |
#25 | |
![]() I'm sure the license bracket won't break. It's firmly attached, and is manufactured from a very tough polymer. ![]() ![]() My friend Andy, a professional diesel mechanic, inspected the bracket and thinks the license plate will be fine. However, I am inclined to add a plastic rectangle to the license bracket, and mount my plate to the plastic rectangle. ![]() Spud ![]()
#26 |
A drop of Locktite is a good idea. I have had license plates shake loose when using just spring lockwashers...
Happy to serve. |
#27 |
I use 1/4" SS nyloc nuts for plates.
#28 | |
![]() Spud ![]()
#29 |
Better than lockwashers. 8)
Happy to serve. |
#30 |
Here are some of the major differences between my CRF250X, and the CRF250R (Race) version of the bike.
CRF250R has a more aggressive camshaft CRF250R has a higher compression piston CRF250R is about 25 pounds lighter in curb weight CRF250X has a wider ratio transmission CRF250X has a side door for easier access to the air filter CRF250X has a larger fuel tank CRF250X has an electric starter, with a kick starter backup CRF250X has a headlight CRF250X has a tail light (mine also has a brake light) CRF250X has a kick stand Because of the headlight and tail light, it was very easy to get a license plate for the CRF250X in Idaho. I merely needed to add the following items. Hydraulic brake switch on rear master cylinder Horn (clown horn is legally acceptable) One mirror ![]() Spud ![]()
