Old 08-17-2012, 11:05 AM   #46
Your carb is based on the Keihin, and that's what was used in old Hondas (like the XR200). You might be able to take the jet into your local Honda dealer and buy a 110 main that is identical to yours. Just don't tell them what it's for...
Old 08-17-2012, 01:49 PM   #47
Enduroadventure   Enduroadventure is offline
that's what i did yesterday and i brought the jets, and carb into the shop, found some slow ones that fit but no main jets.
Old 08-17-2012, 04:04 PM   #48
well ive come to the conclusion im just gonna buy a Mikuni. Does this one look like a solid fit?
http://www.ebay.com/itm/400315824830#ht_3210wt_906
Old 08-17-2012, 04:15 PM   #49
That one is a flange mount. Is your's a flange mount or does it mount directly to a carb holder ('boot', or intake 'manifold') with a circular clamp?
Old 08-17-2012, 04:23 PM   #50
yes the mount is similar. im more worried about the little hole on the top, Mine doesn't have that at all. also the choke looks a little different there is no cable holder, issue here?.
Old 08-17-2012, 04:39 PM   #51
I think the hole you are refering to is where the carb cable mounts.
The choke lever position does not matter as long as you get get to it easily enough and there's room for it to operate. :wink:
Old 08-17-2012, 04:44 PM   #52
the carb i have only has 1 hole in the top where the cable goes. the big one in the middle. i dont have a small one off tot he size as pictured here.
http://www.auctiva.com/hostedimages/...rmat=0&lgdin=1
Old 08-17-2012, 05:18 PM   #53
No worries. That's a vent or something.
Old 08-17-2012, 09:50 PM   #54
That's not a hole. It's ink. It will be a direct fit on your bike, but you'll need to swap your existing choke lever over. You'll need to buy new jets for it, but they're easy to find.
Old 08-17-2012, 10:05 PM   #55
There you go! :P
Old 08-18-2012, 06:21 AM   #56
Alright good enough for me bought.
Old 09-14-2012, 05:07 PM   #57
Finally getting around to looking for jets for my Mikuni. And I was reading some posts on here and I thought I was looking for a 110 main and a 42 slow but I have now read other posts that say 127-132 main. Can someone help me out here I live at sea level what do I need?
Old 09-15-2012, 12:16 PM   #58
With a stock muffler, I'd start with a 110 main and a 25 slow. The Mikuni slow jet numbering system is much smaller than a Keihin, hence your confusion.
