#46 |
2 stroke vs. 4 makes a big difference. Sweet Suzuki though. :P
Happy to serve. |
#47 |
That's right, it WAS a 2 stroke. All the memories of mixing gas and 2 stroke oil.....ah yes.....
#48 |
My Dad had one of these when I was little.
It also had a hi/lo range transmission. http://vroum52.com/kawasaki071009.im...0_g4tr1971.jpg
#49 |
Man....sweet old bikes. Memories........
#50 |
Does anybody know what rear sprocket I could throw on for a little bit more comfy cruisin RPMs?
Would it require a chain change? And where can I get one for cheap?
"I'd rather be riding my motorcycle, thinking about God, than sitting in church thinking about my motorcycle." 2004 Travel-On GY150. 'Chinese Chopper' |
#51 |
It does 65, could prob pull 70. Bike has good power, but when I cruise 55 down the highway (8 miles) to school, its a little high in the RPM range, and uses a little oil (out the crank vent tube) just want it to gear a little higher so it doesnt use when I cruise at 55, almost more for peace of mind than anything
#52 |
I don't know specifically which sprocket would fit, but we can help you figure it out if you remove it and measure it. Tell us the number of bolt holes, the bolt hole diameter, the center hole diameter and the bolt circle.
#53 |
4 bolts, I'll take pictures. Easier maybe to just do a front sprocket change?
I've heard this is much easier. A 17T front would make a huge difference 17/44 =2.59 vs stock 16/44=2.75 But will a larger front clear the case? Thanks New CDI and Coil on the way, we will see how much difference it makes.
#54 |
Intake and exhaust mods with minor carb adjust, can rolling wheelie first, with a little weight distribution and little yank on the bars. Not bad for a 150cc with 2.75 gears.
Major power difference, cant wait to see how the CDI and Coil changes things.
#55 |
You're in uncharted territory; very few members here have modded a 150. If you remove the countershaft cover, does it look like you can accomodate a larger front sprocket? Most serious MX riders leave the cover off anyway, to shed weight and make cleaning easier.
A 40 tooth rear would get you in the same ballpark, although a front sprocket is cheaper. Buy a chain breaker at HF to make link removal simple.
#56 |
Fixed the clutch issue. 20W-50 Castrol Motorcycle oil, and a washer behind the clutch springs, no more slipping.
Also the rear sprocket had a wobble. Excessive clearances between the hub and the sprocket (held in with snap ring) Used a feeler gauge, measured the clearance between the snapright and the sprocket, shimmed behind the sprocket on the hub to compensate, now sprocket is nice and tight.
#57 |
I made a mistake couting sprocket teeth (too many beers in the shop)
I've got 17T/46T combo. Still 2.7 ratio. Looking to acheive more of 2.5 from what I've read. An 18T front would do this, or a 42T rear. Which direction should I go? Tips?
#58 |
I can't imagine fitting an 18 in there. Tell us the rear sprocket specs, and we'll guide you towards a replacement.
#59 |
This might be handy for you:
#60 |
Hate manuals. Went to school for automotive, hope I can handle a motorcycle.
Rear sprocket is 46T, 4 "bolt" (actually located in hub with dowel pins, and held to hub with snap ring.) Will get dimensions tomorrow.
