Old 04-11-2011, 12:33 AM   #1
mizke   mizke is offline
rear wheel replacement options
gio beast wheel chart.. these wheels match the beast rear wheel bolt pattern..
oem wheel size/
make/model oem tire size bolt pattern
ATC 200X, 86-87 (R) 22x10x9 9x9, 4/110
TRX 200, 90-93,96-97 (R) 22x10x8 8x8, 4/110
TRX 200SX, 86-88 (R) 22x11x8 8x8, 4/110
better yet as it turns out there are ALOT of name brand quads that run the 4x110 bolt pattern.. this site has a listing of i think every single quad made by all of the name brand companies listing all of the information above for all quad models..
http://www.mud-throwers.com/atv_wheel_chart
200cc beast replica,carsoli cdi,performance coil,fmf powercore 2,uni air filter,hour/tach meter,jetted mikuni carb,msr bars,moose racing grips,yz250f clutch perch,D.I.D chain
Old 04-11-2011, 12:54 AM   #2
Thanks Mike, that's good to know. It might be cheaper to buy take-offs on CL than to buy new stock tires for the Beast. Plus, there is an opportunity to get a larger wheel.
Old 04-11-2011, 01:11 AM   #3
so far from going over the listing in the link i posted, honda and kiwi are the 2 that run the 4x110mm bolt pattern on the rear wheel..
and ya weld i was thinking more of cl finds, if some one happens to see some wheels listed they could check the year, make and model to that list
also means that we now know what rear wheel spacers to order should some of use want to kick the rear tires out another inch or 2
Old 04-11-2011, 09:02 PM   #4
rotax583   rotax583 is offline
anyone know the bolt pattern on the mini beast and mini atv? even a replacement hub that would have a 3 or 4 bolt pattern from one of the major brands? thanks
Old 04-11-2011, 10:20 PM   #5
get a digital vanier (spelling) caliper.. its a electronic ruler and make sure it does mm.. measure the distance between stud holes on the hub... in the i linkest that site has all the information on how to properly measuring the bolt pattern and it only takes a few seconds to get the measurments
Old 04-12-2011, 10:16 AM   #6
johnwayne   johnwayne is offline
how about the front. i have a new beast 2010 and the front has disks,and the pattern looks the same as the back
Old 04-12-2011, 10:38 AM   #7
That's good to know, johnwayne. I hadn't realized that the new Beast has disc brakes in the front. The front drums and rear disc stop our Beast just fine, but a disc front system would likely be easier for my wife. Does the brake hose split after the master to connect to both wheels? Got a pic?
Old 04-12-2011, 12:14 PM   #8
yes it does split. i will take a few detailed pics of the 2010 as soon as i make it to the shop n wash all the mudd off it.
Old 04-12-2011, 05:53 PM   #9
hmm i might be ordering that 2010 beast front dic setup
