05-07-2017, 08:57 AM | #1 |
pz30 adjustment
i have a pz30 and i was wondering how you would adjust it ?
if anyone will to drop a line much appreciated it . still new to all this lol |
05-07-2017, 09:33 AM | #2 |
Here is some info on how to adjust the carb
So to summarize the steps. Use kit to replace bottom carb screws. ( I ordered a kit so I could replace the screws and the AF adjustment screw.) Use kit to replace Idle mixture screw aka air fuel mixture screw or idle jet adjust to 1 1/2 turns out Replace needle from kit that has the steps and place clip in middle position. Adjust Idle mixture screw for highest rpm. If more than 1 3/4 out replace pilot jet with on 1 step more rich. Repeat this step until right jet is installed. Check throttle response for hesitation from above 1/4 if hesitation increase main jet by one size. When I get engine broke in I can do the plug chop. What I have done so far. Removed carb. Adjusted the AF mixture adjustment located on bottom of carb. 1/2 turn more out. Added two washers under the clip on the needle the stock on does not have more than on clip location. This got the bike so it would start easy and run pretty good. Look for a thread by me about my Brozz and you will find a bunch of info.
2016 Brozz |
05-07-2017, 09:40 AM | #3 |
stupid question but what is the screw on the side of the carb ?
05-07-2017, 09:50 AM | #4 |
Idle turn in to raise idle
2016 Brozz |
05-07-2017, 09:53 AM | #5 |
so the screw on the bottom is a/f mixture screw correct?
05-07-2017, 10:36 AM | #6 |
correct
2016 Brozz |
05-07-2017, 11:12 AM | #7 |
how should it be adjusted ?
05-08-2017, 07:17 PM | #9 |
Is there any way you could post the picture of the screw, because I can't seem to figure out which screw it is myself, trying to tune my bike to full capacity
05-09-2017, 12:09 PM | #10 |
Check out these older posts... they have some good pics.
http://www.chinariders.net/showthread.php?t=5316 http://www.chinariders.net/showthread.php?t=14347 I have a PZ30 on my moto and atv. Mine are from '07-ish time frame and didn't have any of the tamper-proof stuff on it. I've found mine very tuneable... using jets bought off fleabay. Cheers!
'20 TaoTao Hellcat 125 "grommet" '04 Yamaha TTR-125LE '00 Yamaha TTR-90 '07 Kinroad XT200GY Runmaster (sold) '07 KMD GY6 150cc ATV (sold) '07 Kangchao 250cc ATV Monster (sold) Baja Moto DB-30 "Doodlebugs"(x3) (sold) '06 Hi-Bird 200 parts bike (sold) |
05-09-2017, 02:12 PM | #11 |
I adjusted my vavles but now I hear a clicking noise. Idk if that's a good sound or not. Any ideas on how the motor should sound?
05-09-2017, 03:32 PM | #12 |
Here you go- http://bfy.tw/Bgtw
05-10-2017, 02:14 PM | #13 | |
I set intake valve to .002" and exhaust valve to .003" on my CG engines and I don't have loud or very noticeable tapping/clicking. But the 'ole saying is "a tappy valve is a happy valve" Cheers!
08-19-2020, 12:11 AM | #14 |
If there's any of you still out there I need the help I'm figuring it out the idle adjustments on pz 30 carburetor jet number 110 and pilot jet 40 what do I do I live I nyc ?????
