Old 05-08-2015, 09:35 AM   #1
Krasi_BG   Krasi_BG is offline
Riding a Puzey :)
Today I've finally gotten around to snap some pictures of what I got myself some weeks ago.
This must be the mother of all exotics - a South-African brand, made in China, and is called Puzey. Model is XTR4:
It's got a Loncin 300cc engine, which is supposed to be based on KLX300. So much I can confirm that it uses KLX300 oil filter:
So far I can only say positive things about the bike. It doesn't show many "Chinese" features. On the contrary, there are many CNC parts on it, for example:
Suspension is fully adjustable, and there's even a patented system for lowering the rear end (I haven't played with that yet):
It comes with a 36mm flat-side Koso carb, which is nice (for me at least ):
One of the bugs is that the speedo is basically useless as the numbers it shows are more close to random, than to actual speed:
I got the bike cheap, as it was a leftover, showroom unit at a UK importer. I paid 1000GBP for it (I'll leave the currency exchange to you). There are some "marks" of that it has sat for a while, like the stickers are a bit dark and peeling along the edges. There are some small bits of rust on some nuts and bolts, but nothing I can't live with.
Initially the bike came with a 14-52 sprockets, which was way too low gearing. I tried going to 14-46, but it was still low, so now I'm on 14-38 and it's about OK.
Overall I have to say I'm MORE than pleasantly surprised with what I got. As Top Gear would say, "It's a good bike. Without the words "for the money". It's a good bike, full stop."
Quality and performance is much better compared to my wife's Skyteam for example. And both bikes were manufactured in 2011! I can only hope that Puzey has raised their quality since then, so the new bikes must be even better.
Finally, I guess it's time I admit I'm all Chinese these days :
Old 05-08-2015, 10:33 AM   #2
Mudflap   Mudflap is offline
Nice looking bike.
Old 05-08-2015, 12:02 PM   #3
Lovely bike! I especially admire the TIG welding on the swingarm, near the adjusters.
Is there a designation on the motor, perhaps near the shifter? That's a new design to me.
You have an impressive China stable! Is that a 140cc pit bike?
Old 05-08-2015, 12:09 PM   #4
Adjuster's Avatar
Very nice. The quality of that swing arm weld alone looks top notch.
Old 05-08-2015, 12:10 PM   #5
Adjuster's Avatar
LOL you can't help going thru the photos and not notice that nice weld.
Old 05-08-2015, 12:18 PM   #6
ripcuda   ripcuda is offline
ripcuda's Avatar
That Puzey looks like a pretty nicely put together bike!
Nice stable of bikes!
Cheers!
'20 TaoTao Hellcat 125 "grommet"
'04 Yamaha TTR-125LE
'00 Yamaha TTR-90
'07 Kinroad XT200GY Runmaster (sold)
'07 KMD GY6 150cc ATV (sold)
'07 Kangchao 250cc ATV Monster (sold)
Baja Moto DB-30 "Doodlebugs"(x3) (sold)
'06 Hi-Bird 200 parts bike (sold)
Old 05-08-2015, 12:45 PM   #7
Engine code is LL178MN. It's liquid cooled, and the bike has a radiator fan as a standard too (I think KTM charge extra for that?).
Indeed all welds look good and as they should be. Bolts are also not of the greenish-dark-gray colour, but zinc coated and seem more solid and durable. Time will tell if the threads will shred.
Plastics are flexible, rather than brittle.
The handlebar is "fat", i.e. 1 inch. I already managed to drop it from the side stand and it only wrinkled the coating on the inner bend where it flexed a bit. The front brake lever is of the correct length now too
All in all, if you don't know it's Chinese you'd have to look a bit deeper to find evidence. Two of the giveaways are the kick starter and oil filling cap. They seem way shiny and "cheesy" and not quite in tune with the rest of the details on the bike. I know I sound like bragging, but credit should be given when due, and Puzey so far get mine. Long-term durability is yet to be seen.
As for the pit bike, yep, it's 140cc. And it's surprisingly perky while hauling my 200+ -pound a$$ around! The only remark about it is that neutral gear is at the very bottom, so if you don't count precisely while downshifting, all you get is high engine revs when actually you're in desperate need for propulsion
Old 05-08-2015, 01:27 PM   #8
ripcuda's Avatar
I can relate. My Kinroad is 5 down, neutral at the top. Overcoming years of 1 down, 4 up shifting is going to be fun. Feels weird to toe-up downshift while coming to a stop. It's backwards. I'd like to add a heal shifter to the shift lever so I could tap down, on the heal part, for downshifts. Doesn't look like it'll fit too easily.
Cheers!
'00 Yamaha TTR-90
Old 05-08-2015, 02:43 PM   #9
That is a nice looking motorcycle, as is your entire stable of Chinese bikes. Once you go Chinese, you will never go back.
Old 05-08-2015, 07:10 PM   #10
humanbeing's Avatar
Originally Posted by krasi_bg View Post
engine code is ll178mn
YF300 ? http://www.loncinindustries.com/en/m...ine/Index.aspx
Old 05-08-2015, 10:55 PM   #11
humanbeing's Avatar
Originally Posted by ripcuda View Post
I can relate. My Kinroad is 5 down, neutral at the top...add a heal shifter ...
At least it isn't that "suicidal" rotary...
Genuine :http://item.taobao.com/item.htm?id=36796553530 | Generic :http://item.taobao.com/item.htm?id=13371757816
To "mainsteram" needs tool open the case ... & these http://item.taobao.com/item.htm?id=13346435666 | http://item.taobao.com/item.htm?id=10133081888 btw there's also another version (14mm / not 20mm). ENSURE which is which b4 buying parts , otherwise ...
http://www.motorfans.com.cn/bbs/view...14319&page=2--
Old 05-09-2015, 12:15 AM   #12
As stated on mychinamoto--I like the Puzey bikes. We had them available in the US as Pitster Pro in 250cc form; in the UK, they were rebadged as CCM bikes, as well as apparently Puzeys!
Old 05-09-2015, 12:16 AM   #13
Oh, and here is the OEM...
http://www.shuopuscience.com/
Old 05-09-2015, 01:21 AM   #14
ripcuda's Avatar
Genuine :http://item.taobao.com/item.htm?id=13371757816 | Generic :http://item.taobao.com/item?id=39464525801
To "mainsteram" needs tool open the case ... & these http://item.taobao.com/item.htm?id=13346435666 | http://item.taobao.com/item.htm?id=10133081888 btw there's also another version (14mm / not 20mm). ENSURE which is b4 buying parts , otherwise ...
Wow... so it's possible to change the gear shift pattern to standard. That's very cool. I'm not ready to split the cases and perform open-heart surgery just yet... but it's good to know it's possible. Thank you for sharing.
Cheers!
'00 Yamaha TTR-90
Old 05-09-2015, 12:15 PM   #15
That engine looks like a good score. A six-speed, 25.88hp, and honest 292cc, electric and kick start; it's got everything I need. http://www.loncinindustries.com/en/m...780128#proFlag
Search this Thread:
Advanced Search
Display Modes
