Old 08-02-2020, 02:30 PM   #1
Medicbobs   Medicbobs is offline
Question What VM22 jet kit do you guys use?
I have a Vader 125cc with a knock off Mikuni VM22 and was wondering what jets you guys use? The one I bought already has a 95 in it.
Old 08-02-2020, 09:10 PM   #2
Big Bird   Big Bird is offline
Big Bird's Avatar
I'm running a 100 with needle 1 clip richer.
Wingsmoto kit from Amazon.
2020 Boom Vader Gen 2
2019 CSC TT250
2021 Kayo Fox 70
Old 08-06-2020, 02:42 PM   #3
Awesome man. Thanks. The carb I have has a 95 in it. You think I should just drop the 100 in it before I install it?
Old 08-06-2020, 03:52 PM   #4
Big Bird's Avatar
I'm at 50' above sea level. So it depends.
2019 CSC TT250
2021 Kayo Fox 70
Old 08-06-2020, 03:17 PM   #5
dirtbkr188's Avatar
You'd probably be better off trying the #95 main before anything else, it might be fine for your elevation.
Old 08-06-2020, 06:18 PM   #6
ripcuda   ripcuda is offline
ripcuda's Avatar
I have the vm22 on my Hellcat 125... using the stock intake and airbox.
I'm running the stock pilot. Not sure on how many turns on the A/F screw.
My needle on the throttle has a small washer underneath it. I actually had to lower my needle (raise clip) to lean out the mid-range... it was bogging and stalling bad.
I drilled out my main to ~#98-ish... but it is still not enough. I can't fully rev it out. Going to try #100 next.
I'm at 2200ft elevation.
Cheers!
'20 TaoTao Hellcat 125 "grommet"
'04 Yamaha TTR-125LE
'00 Yamaha TTR-90
'07 Kinroad XT200GY Runmaster (sold)
'07 KMD GY6 150cc ATV (sold)
'07 Kangchao 250cc ATV Monster (sold)
Baja Moto DB-30 "Doodlebugs"(x3) (sold)
'06 Hi-Bird 200 parts bike (sold)
Old 08-07-2020, 01:00 AM   #7
Cheers!
I'll have to see how it goes with the stock 95. I bought a pack of jets so I'll try to tune it if it needs it. I'm not too experienced on jetting, so I guess as long as it isn't cutting out full throttle? I'm at about 6500ft.
Old 08-07-2020, 02:22 AM   #8
Big Bird's Avatar
It depends on throttle position on what you want to adjust. Idle to part throttle is going to be the idle mixture screw/pilot jet, mid range is your needle, full throttle is your main jet. Their is overlap though. Too rich it will surge and pop, too lean it will bog.
2019 CSC TT250
2021 Kayo Fox 70
Old 08-09-2020, 09:17 PM   #9
That makes sense. I appreciate the input. Guess I'll just have to try the stock 95 and see how it runs.
Old 08-10-2020, 02:54 PM   #10
ripcuda's Avatar
Finished tuning my HC this past weekend.
Stock exhaust
Stock intake and spacer (spacer tapered a tad to smooth airflow out of larger diameter carb into smaller diameter spacer)
Airbox removed... running cheap pod filter
VM22 carb
#100 main jet
stock pilot jet
A/F screw at 1 turn out
Throttle needle lowered - raised c-clip to top notch - still has stock washer under the needle clip
2200ft elevation
runs great... full rpm... max 55mph indicated with my #210butt on it. Starts quick... great throttle response. I'm calling this one tuned.
Good luck dialing in your carbs!
'00 Yamaha TTR-90
Old 08-10-2020, 04:20 PM   #11
Stock exhaust
VM22 carb
#100 main jet
stock pilot jet
2200ft elevation
Hell yeah man! Thanks for the reply. I keep thinking I might throw this 100 main jet in. Do you have a real mikuni or a knock-off? I got the knock-off. Heard it runs fine as well.
Old 08-10-2020, 09:37 PM   #12
ripcuda's Avatar
My vm22 is a knock-off... the $30 one on fleabay. Works better than the stock PZ-25 it came with. I like the enricher on the carb much better than the PZ-25 choke plate. It makes a perfect starting high idle. And using the stock intake points the carb rearward putting the enricher lever on the easy to reach left side.
Cheers!
'00 Yamaha TTR-90
Old 08-18-2020, 01:17 PM   #13
sv650touring   sv650touring is offline
my Hellcat has the following mods:
- VM22 knockoff kit from eBay
- Aluminum intake that was included with carb (larger diameter than stock)
- enlarged opening in paper carb gasket so it is no longer a restriction
- drilled out welding inside header pipe so it wasn't such a large obstruction (used a step drill)
- oiled foam filer (not the K&N-style pleated cotton one included with the carb)
- no airbox, carb pointed forward
With that setup, it kept running lean even with a #125 jet! It was surging and the plug tip was whitish. Since I only had jets up to #125 and I didn't want to wait for the new ones to get here, I took the stock jet and drilled it out until it was slightly bigger than the #125. I actually put the jet in my drill chuck and the tiny drill bit in a vise.
I'm not sure exactly how big the hole was when I was done, since the bit was a 1mm I think. The drill bit had a little more wiggle room in this jet than in the #125. After that it ran pretty good, so I left it in. My bigger jets came in the mail, but I haven't had time to try them yet
I left the needle and pilot jet alone. I think I set the pilot screw at 1.5 turns out
Old 08-27-2020, 03:53 PM   #14
Big Bird's Avatar
I'm running a 110 now. Initially I tuned the carb when it was ~ 100 degrees every day. Last night I rode it in 75 degree weather and the bike was not happy. Test rode it today at 75 degree temps with the bigger jet and it's running good now. I will see how it reacts once it warms up today. Would be nice to get a jet in there that covers a broad range of temp difference just adjusting the needle.
2019 CSC TT250
2021 Kayo Fox 70
Old 09-10-2020, 10:17 AM   #15
I'm with you on that. Colorado is bi-polar as hell right now. I'm riding at 34 degrees with a 110 main and it's doing ok, but the 95 was running too lean and killing after a couple minutes of riding.
I also took that charcoal canister out because I felt it was either pinching my fuel line or choking it somewhere. I'm going to try and tune it again. It'll be in the 70s this weekend.
boom, grom, mikuni, vader, vm22
