Old 05-07-2017, 08:57 AM   #1
kain9295   kain9295 is offline
pz30 adjustment
i have a pz30 and i was wondering how you would adjust it ?
if anyone will to drop a line much appreciated it . still new to all this lol
Old 05-07-2017, 09:33 AM   #2
goat67   goat67 is offline
goat67's Avatar
Here is some info on how to adjust the carb
So to summarize the steps.
Use kit to replace bottom carb screws. ( I ordered a kit so I could replace the screws and the AF adjustment screw.)
Use kit to replace Idle mixture screw aka air fuel mixture screw or idle jet adjust to 1 1/2 turns out
Replace needle from kit that has the steps and place clip in middle position.
Adjust Idle mixture screw for highest rpm. If more than 1 3/4 out replace pilot jet with on 1 step more rich. Repeat this step until right jet is installed.
Check throttle response for hesitation from above 1/4 if hesitation increase main jet by one size.
When I get engine broke in I can do the plug chop.
What I have done so far.
Removed carb.
Adjusted the AF mixture adjustment located on bottom of carb. 1/2 turn more out.
Added two washers under the clip on the needle the stock on does not have more than on clip location.
This got the bike so it would start easy and run pretty good. Look for a thread by me about my Brozz and you will find a bunch of info.
2016 Brozz
Old 05-07-2017, 09:40 AM   #3
stupid question but what is the screw on the side of the carb ?
Old 05-07-2017, 09:50 AM   #4
goat67's Avatar
Idle turn in to raise idle
2016 Brozz
Old 05-07-2017, 09:53 AM   #5
so the screw on the bottom is a/f mixture screw correct?
Old 05-07-2017, 10:36 AM   #6
goat67's Avatar
correct
2016 Brozz
Old 05-08-2017, 07:17 PM   #7
Ivang217   Ivang217 is offline
Ivang217's Avatar
Is there any way you could post the picture of the screw, because I can't seem to figure out which screw it is myself, trying to tune my bike to full capacity
Old 05-09-2017, 12:09 PM   #8
ripcuda   ripcuda is offline
ripcuda's Avatar
Check out these older posts... they have some good pics.
http://www.chinariders.net/showthread.php?t=5316
http://www.chinariders.net/showthread.php?t=14347
I have a PZ30 on my moto and atv. Mine are from '07-ish time frame and didn't have any of the tamper-proof stuff on it. I've found mine very tuneable... using jets bought off fleabay.
Cheers!
'20 TaoTao Hellcat 125 "grommet"
'04 Yamaha TTR-125LE
'00 Yamaha TTR-90
'07 Kinroad XT200GY Runmaster (sold)
'07 KMD GY6 150cc ATV (sold)
'07 Kangchao 250cc ATV Monster (sold)
Baja Moto DB-30 "Doodlebugs"(x3) (sold)
'06 Hi-Bird 200 parts bike (sold)
Old 05-07-2017, 11:12 AM   #9
how should it be adjusted ?
Old 05-07-2017, 12:04 PM   #10
rvl8rida   rvl8rida is offline
Did you read the other post?
Old 08-19-2020, 12:11 AM   #11
Richey221   Richey221 is offline
If there's any of you still out there I need the help I'm figuring it out the idle adjustments on pz 30 carburetor jet number 110 and pilot jet 40 what do I do I live I nyc ?????
