Old 07-01-2011, 11:00 AM   #1
rlaslo   rlaslo is offline
GIO scooter
I have a 500 w GIO scooter and the signals don't work . Is there a fuse for this . Where can I find a wiring diagram ?
Old 07-01-2011, 11:28 AM   #2
I don't have a wiring diagram. Maybe there is a bad ground; start by taking the front shrounds off and inspecting the connectors.
Old 07-02-2011, 07:22 AM   #3
signals
That might be the case . I was told by the person it stopped working after she hit a large bump in the road . I will have the trace the wiring with an ohm meter .
Old 07-02-2011, 10:29 AM   #4
katoranger's Avatar
Probably just a loose connection someplace.
Old 07-10-2011, 01:31 AM   #5
Have you had any luck finding the problem? If you have time, please give us an update.
P.S. If you use a unique, descriptive title for each thread, you are much more likely to generate good, informed responses from the members of these forums.
