Old 05-05-2007, 10:00 AM   #1
kidsquad   kidsquad is offline
Engine oil weight, etc????
Newbie here again,
Got the 110cc quad the other day, Eagle brand, aka Zhejiang Peace Trade Group,lol. After setting it up, took it for a spin and this little things purrs like a kitten, more than the 7 yr old will need, had to turn the screw for the throttle in almost all the way.Was reading the owners manual and it calls for 10W40 oil, this seems a little heavy to me. Anyone else have any ideas what I should use? I would like to get the factory fill oil out after a few hours and use a quality brand name. I also am wondering what screws do what on the carb if I need to fine tune it. I know which one empties the bowl for the gas, but there are a couple of other screws that I am not sure of the function. Thanks for any help. The owners manual appears to be a generic "cover most" models type manual, but the parts book is quite specific to this model.
Old 05-05-2007, 11:35 AM   #2
RPM   RPM is offline
Send a message via Yahoo to RPM
There's only 2 screws other than the drain. The larger screw with the spring is the idle adjustment and the smaller inset screw is the mixture adjustment.
RPM - REV IT UP! (REDLINE is OPTIONAL)
Feel the RUSH ... it gets better all the time!
Old 05-05-2007, 01:19 PM   #3
Is there a way to determine what the proper mixture setting is?
It seems to run fine, but I am just curious.
Thanks
