Old 04-24-2007, 02:35 PM   #1
Guest
Posts: n/a
Jetmoto vs Viva rear suspension
Just wondering if the Viva has this type of linkage or are using a different system.
This one is on the newest Jetmoto made by Kaier, not the older model made by Shineray.
Felt like a hardtail until it got about 100k on it then the shock loosened up and it now has around 6-7 inches of travel, just guessing, have'nt
actually tried measuring it yet.
Old 04-24-2007, 03:17 PM   #2
TheOtherRide   TheOtherRide is offline
Send a message via Yahoo to TheOtherRide
Hey, that looks familiar! I think that's pretty similar to the Viva's...Akonababe or msRandi said they'd loosen up with time. I've been comparing my bike's setup to my boyfriend's KLR650. The KLR seems more mobile, but basically the same concept with longer cradle 'arms' & links.
~Pauli~
Former 2006 Viva VX200SX owner
Old 04-24-2007, 03:39 PM   #3
Guest
Posts: n/a
Sometimes looks can be deceiving.
Old 04-24-2007, 04:25 PM   #4
red2003   red2003 is offline
No way you are getting 6 - 7 inches of travel out of that linkage. It's the same as the Viva, Hi-Bird, Roketa, etc. If you measure you'll see you only have about 3 inches then the scissor is fully extended and there is no more suspension except for what the linkage will flex. Been there, RE-done that. Read here:
http://www.chinariders.net/modules.p...ewtopic&t=1315
Old 04-24-2007, 08:42 PM   #5
ob1   ob1 is offline
That "dog-bone" looks bent to me.
Definitely read Red's linkage mod thread!
Old 04-24-2007, 09:25 PM   #6
SamM   SamM is offline
This is what I'll be using to replace the stock shock and linkage on my new Viva. The mount on my swingarm has been cut off already. I'll be making one or two new front links that run back to the XR200 link. Need the parts in hand to see what will be the best.
I'm looking forward to gettin' after it. Hopefully, it will go together quickly. Stay tuned!
2005 Yamaha R1 rear shock
1995 Honda XR200R linkage
2013 Jeep Wrangler Sahara MOAB
2005 BMW E53 X5
2011 Schutt Industries LTT-HC LQG trailer
2017 Coleman CT200U
1978 Yamaha SR500E
1979 Yamaha XS650 Special II
Old 04-24-2007, 09:53 PM   #7
Guest
Posts: n/a
Sam, is your linkage the exact same as on the Jetmoto.
Old 04-24-2007, 10:18 PM   #8
Almost! It was very similar. However, my shock was resting on the rear mounted dog bone! Basically, making it a hardtail. Actually, the Jetmoto suspension looks like it would work. A bit beefier too! My swingarm mount wasn't underneath, it was below but more in front of the swingarm. If that's clear!
It's not the same anymore. Replacing all of it.
2005 BMW E53 X5
2017 Coleman CT200U
1978 Yamaha SR500E
Old 04-24-2007, 10:43 PM   #9
Guest
Posts: n/a
Somebody told me recently that the original Lifans which most of these seem to be copied from were originally measured and copied from an XL-XR100. If this is the case that may be an easier solution.
It seems the chinks never really copy anything, they just make it look like a copy, if it works fine, if not oh well.
I've seen at least 3 different types of these and none of them seem consistent in measurements or in the way they are assembled.
Old 04-25-2007, 12:18 AM   #10
Viva stock linkage
~Pauli~
Old 04-25-2007, 12:26 AM   #11
liverchip   liverchip is offline
Send a message via MSN to liverchip
Hey your dogbone isn't bent.
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 04-25-2007, 08:18 AM   #12
Pauli shows a good picture there. I was thinking that rear bracket was more forward than the Jetmoto. Guess not! I took a torch mine and cut it off. In her picture you can see the dog bone is much closer to bottom shock eye. Mine was right up against it and had worn the paint off the dog bone.
2005 BMW E53 X5
2017 Coleman CT200U
1978 Yamaha SR500E
Old 04-28-2007, 02:21 PM   #13
willshoemaker   willshoemaker is offline
Send a message via AIM to willshoemaker
So in conclusion the stock chinese suspension sucks?
Will
P.S. Sorry for bringing up the dead :?
Ride It Like You Stole It.
"Time is an abstract concept created by carbon based lifeforms to monitor their own decay."
