11-06-2010, 03:12 AM | #1 |
I Love Retrofit Electrical Boxes
I had to move an electrical box from one side of the wall to the other, and the new side is finished. As a result, I didn't want to open a finished wall and have to patch it again.
Enter the retrofit box. No studs necessary; it has its own clamping device that secures it firmly to the drywall. I've used them before and have complete confidence in them for duplex receptacles. Here's the hole I cut in preparation for the new box: This is the retrofit box. Note the clamps on the top and bottom; those are drawn in as you tighten the screws; Just kick the bottom end in and then the top. Presto! The finished product:
11-06-2010, 07:51 AM | #2 | |
Re: I Love Retrofit Electrical Boxes
Big fan of those, myself. Made my own LAN wiring and jacks that way... Bill R |
11-06-2010, 02:03 PM | #3 |
That's an excellent idea Bill. :idea:
I might use them for telephone jacks, instead of surface mount.
11-06-2010, 04:24 PM | #4 |
I have seen them in the store. Great idea.
11-08-2010, 01:15 AM | #5 |
Uuuuh.. pardon my total non renovation electrical skills. I get how you put the box in, but me confused on how the wiring works. You had no wires behind the wall neither right? So how you wire the box up without making more holes?
Perhaps I'm missing something.. |
11-08-2010, 10:28 AM | #6 |
Those are sweet. Makes life nice. So does fish tape!
I had to do a bunch of electrical work to my friends cedar house this weekend also. Hung two ceiling fans on 2 foot extension rods. The problem? No sheet rock to hide things! 8O Painted all the Romex, c-boxes, hardware and switch boxes dark brown and run everything behind beams and tucked in corners to try to 'hide' it as much as possible. Turned out ok in the end. My apologies for the big photos. My camera phone seems to do that. :x
11-08-2010, 11:40 AM | #7 | |
If I was starting with no existing outlet and needed wire, I would have fished from either the attic or the basement. I'll be happy to show you how a fishtape works when you come over next. When will that be?
11-08-2010, 02:04 PM | #8 | |
More info than you ever thought you didn't need... That and a veerryyy long drill bit... Flexible Drill Bit Fish Tape And the "UDAMAN TOOL" Paint Ball Pull Line Shooter or I gotta get me one of these just for the COOL factor... Got into the attic or crawl space, drill thru the sill into the wall space where you want the wire/box and away you go... Uh, make sure you measure real good, so the holes aren't thru the ceiling, right next to the wall... :x Yep, did that...crown moulding to the rescue... Bill R |
11-08-2010, 07:36 PM | #9 | |
Totally don't know. Haven't been out your way in a number of weeks. No gas money. 8O |
11-09-2010, 10:47 AM | #10 | |
11-10-2010, 01:16 AM | #11 | ||
Excellent job on the fan, BTW. It must be very hard to discreetly wire an open beam ceiling.
11-10-2010, 01:25 AM | #12 | |
I'm disappointed that I hadn't heard of Flexidrills before, especially since I'm Canadian, and I'm a tool freak. Love Klein, hate their prices. My steel fishtape was less than $10 at Princess Auto, and it hasn't broken or kinked on me yet. Princess also sells those nifty automatic wire strippers for $12.00 on sale. They're probably made in the same factory as the Klein version, too. Love the cable launcher idea! I got a kick out of the masking tape reference; I wonder if masking tape would stop the lead ball from going through the roof.
11-10-2010, 04:54 PM | #13 | ||
The other links were just quick searches. I couldn't/wouldn't afford the Klein stuff either. The first cable launcher I ever saw was a converted kids stopper gun. Tied fishing monofilament to the dart and used that to pull the larger string to pull the wire... :wink: Bill R |
12-27-2010, 10:13 PM | #14 |
I was just thinking of how to accomplish something today and remembered this topic
I need to get a vga and audio cable from one room to the next... I can just put one of these on each side of the wall, I guess the only trouble will be finding the short connector wires for inside the wall.
12-28-2010, 03:25 PM | #15 |
Short connector wires? I don't understand. Do you mean a VGA cable that changes gender?
