Old 07-09-2010, 01:32 PM   #1
yasting   yasting is offline
This wire is normal?
When i opened the box of my new Rebel T3, i saw a piece of wire that is cut.
That's normal. :roll: Where this wire is supposed to be connected?
Old 07-09-2010, 02:37 PM   #2
waynev   waynev is offline
That's the clutch lever, right?, if so it's possible that the brake and clutch levers are the same assemblies and the brake lever will have a switch to control the brake light, not needed on the clutch.
Old 07-09-2010, 06:30 PM   #3
TurboT   TurboT is offline
I'd concur, and another true example of the china power sport market being a bit 'unrefined'
Old 07-09-2010, 07:02 PM   #4
Think of it as a built in spare for WHEN the other one fails. :roll:
Old 07-11-2010, 09:34 AM   #5
Finally, it's not like the other side.
Old 07-11-2010, 10:57 AM   #6
The controls that are used on these machines were originally for street bikes and so on. The switch on the clutch lever was likely a safety switch in the original application, but it was not used on your atv. If your atv starts and runs without it, forget it.
