Old 07-06-2010, 01:09 PM   #1
patspark   patspark is offline
qingqi renegade 125 wireing diagram
hi just joined the site i have bought a quigqi renegade 125.
i have a problem with the electrics.
i am getting no spark. i have hunted high and low for a wiring diagram
so that i can trace the fault .
can anyone tell me where i can find one .
thanks in advance
Old 07-06-2010, 06:11 PM   #2
katoranger's Avatar
Not sure about a wiring diagram, but my first guess would be a cdi box after trying a new spark plug.
Then check behind the sprocket cover for damaged wires.
Allen
Old 07-06-2010, 08:02 PM   #3
hi katoranger yes think that is a possible . also suspect a problem with the kill switch the fault has got steadily worse now i have no spark at all .
started off with problem starting after a run.
i would just like to get a wiring diagram so that i may follow the starting circuit through to see where i am loseing it
Old 07-07-2010, 10:27 PM   #4
Oengus   Oengus is offline
I really believe that Qingqi has service manuals for all of it motorcycles.
I wonder if sending an email to them with your VIN number may get you one or point you to a source of for one near you….that being those who distributes the bikes in your area have access to service manuals.
Address:No.34,Heping Road,Jinan,China
P.C.:250014
TEL:0086-531- 86599753 86599758
FAX:0086-531- 86986806
E-mail:qingqimotor@qingqi.com.cn
Keep in mind wiring diagrams do not exist outside a service manuals…that’s what you actually want the service manual…which always includes a wiring diagram.
They sell service manuals so posting them online would be offering copyrighted material for free.
Taking a copy and handing it out helps one person put also shafts the people that actually spent the resources to create it in in the first place.
It's interesting because what you want exists, so go to the source and ask were can I get it.
It is so difficult even to find the bikes and sources of them...the same for the documentaion...but it's bascially the same they follow the same chain.
You know who makes it....then who sold it in your area or does now?
If not locally then who close to you does sell that bike...they have access to documentation, Qingqi should know that if not then they should supply the document or even the part themselves and direct.
Old 07-08-2010, 03:25 PM   #5
Reveeen   Reveeen is offline
Because we are discussing spark I would suggest identifying your CDI unit. That will give you a clue as to how the ignition is wired.
The two main types are:
The small unit as seen here:
http://www.partsforscooters.com/150-...9&category=393
Larger one here:
http://www.partsforscooters.com/CDI_...ategory=123337
I am told that this is the CDI you should have?
http://www.telecable.es/personales/a...I%20qingqi.jpg
Post #2 here outlines what/where and some internet trolling may turn up a wiring diagram:
http://www.mychinamoto.com/forums/sh...facturer-Links
Old 07-10-2010, 05:44 AM   #6
humanbeing's Avatar
Same Model as BAIMO Renegade / SINNIS Vista
-CG125 Ohv Machine & Suzuki Marauder body
Pls refer to CG125 & clones diagram
