Old 02-27-2010, 11:16 AM   #1
Oengus   Oengus is offline
TMEC-200 Dual Sport Bike
If money is an issue then how about a TMEC-200?
http://lessstresspowersports.com/car...products_id=36
Model: TMEC200-1 Manufacturer: TEMC Engine: Single cylinder, 4-stroke, air-cooled Engine Displacement: 196.98cc Compression Ratio: 9.2:1 Bore x Stroke: 63.50mm x 62.20mm Max Power: 14.08 hp @ 8500 rpm±350 rpm Max Torque: 9.96 lb-ft @ 6500 rpm±350 rpm Engine Oil Volume: 1 L Start Mode: Electric start Ignition Mode: CDI Max Speed: 75 MPH Brake System: Hydraulic Disk (front and rear) Wheelbase: 1350mm Min Ground Clearance: 230mm (9.06 in) Overall Dimension (LxWxH): 2045mm x 840mm x 1120mm Max Load: 159kg (350 lbs) Net Weight: 123kg (271 lbs) Fuel Tank Capacity: 3.17 gallons
Old 02-27-2010, 01:31 PM   #2
That is a nice find, Oengus. I wanted to give your discovery more exposure, so I moved your original post, and created a new thread on this bike.
The TMEC seller has two shops in Utah, and I believe he had a display last fall at the Utah State Fair. If my memory is correct, I believe I saw the supermoto version of this bike when I visited the Utah State Fair.
I gave the bike a close up inspection for a few minutes, and the build quality seemed to be pretty good. Below is a link to another vendor for this motorcycle.
http://www.atv4usa.com/proddetail.asp?prod=TMEC200-1
Old 02-27-2010, 02:10 PM   #3
Jim   Jim is offline
That's a good looking bike.
"Be excellent to each other"
Old 02-27-2010, 02:22 PM   #4
THAT looks like a good bike! Good price too. What we need now is a guenia pig...
Old 02-27-2010, 02:51 PM   #5
That is a cool looking bike! And I really like the dual piston rear wheel disc.
Old 02-27-2010, 03:09 PM   #6
katoranger's Avatar
OHV pushrod workhorse engine.
Looks like great brakes.
Old 02-27-2010, 03:13 PM   #7
katoranger's Avatar
Spud, we are going to need you to take the zong down to Utah.
http://lessstresspowersports.com/car...age=contact_us
Maybe we can set up a chinarider review.
Old 02-27-2010, 03:17 PM   #8
katoranger's Avatar
I wonder what the freight charges are. I don't see any shipping prices.
It looks like a good deal, but that could be a deal breaker.
Old 02-27-2010, 03:18 PM   #9
Here is link to TMEC, Crazy Carl at MYCHINAMOTO.com covered the Dealer Expo, but he had no comment on them. They and the bikes were there, looking for dealers.
TMEC website: http://www.tmec.net.cn/index.htm
They seem to have some interesting products coming out of Jiangsu Province. I am fairly certain that the major supplier for what was the Tank line is in that area and is called XLMCO which is an acronym for Jiangsu Xinling Motor Co.
I would say these new bikes seem to be of better quality? Better then the old inventory being heavily discounted?
I personally do not think that warranty needs to go beyond 12 months, its about the break in/ wear in that is what should concern people. If the engine has a flaw that’s when its likely to show up. Warranties should be all factory backed…not distributor added.
I would say these new bikes are better quality? Better then the old inventory being heavily discounted?
I would contact TMEC and find out who is the USA distributor and if products are warranted from the factory. The engine specs are real close to that of the Qingqi.
Old 02-27-2010, 03:57 PM   #10
TheRealWorld   TheRealWorld is offline
Wow, you guys always keep thing interesting! But make sure to check out that $1000 Zong Sierra also!
Old 02-27-2010, 04:15 PM   #11
here is the engine
http://www.tmec.net.cn/html/articles...?ArticleID=289
Old 02-27-2010, 04:49 PM   #12
One of the TMEC dealerships is in American Fork, Utah, which is only a short distance south of Salt Lake City. I would guess this dealership is the one that had the display I visited at the Utah State Fair last fall. Pitster Pro is also located less than ten miles away, in Lindon, Utah. Therefore, one reviewer could see both the TMEC 200, and the Pitster Pro LXT 400 during the same trip.
Old 02-27-2010, 05:21 PM   #13
So do we still talk about whether it is a balanced engine or not. Some were and some were not? How about this one.
Old 02-27-2010, 08:29 PM   #14
alkamp   alkamp is offline
hmm, might have to move to a more street legal, easily licensed, friendly state
Old 02-27-2010, 08:43 PM   #15
Several people have successfully registered the Zongshen 200GY-2 in California.
