Old 07-28-2006, 08:25 PM   #1
frostbite   frostbite is offline
The OFFICIAL DS bike prep thread
I've just added a new bike prep checklist to the content section. Please post any additions/suggestion/corrections to this thread.
Thanks,
Frostbite
"The beatings will continue until moral improves"
Old 07-29-2006, 06:12 PM   #2
ohbowhntr   ohbowhntr is offline
USE LOCK-TITE and LOCK-WASHERS!!!!!!
ADD LOCK WASHERS TO THE EXHAUST SHIELDS!!!!
ADD LOCK WASHERS AND LOCK-TITE TO THE BATTERY BOX!!!!!
RE-WIRE or TAPE ALL EXPOSED ELECTRICAL CONNECTIONS!!!!!
CHECK CHAIN TENSION!!!!
ENJOY THOROUGHLY!!!!!
~~ DOUG ~~
Old 08-01-2006, 12:36 AM   #3
Beerslayer   Beerslayer is offline
Check the gas tank for crud before filling it with fuel for the first time. If it doesn't pass the white glove test, take it off and rinse it out before filling.
Old 08-01-2006, 10:22 PM   #4
dlunt   dlunt is offline
Send a message via MSN to dlunt
Check to verify that the rear disc brake is not adjusted too tight. It will swell and start tightening while riding. It will slow the bike down and smoke the brakes.
Old 08-08-2006, 03:15 PM   #5
HotelRed   HotelRed is offline
Look at the license plate holder where it bolts to the fender. Consider placing a piece of metal on the underside. One of my bolts pulled through.
(Roketa RSM 200).
John
Old 08-09-2006, 12:02 PM   #6
Ensure to apply a thin layer of grease to the seal of the odometer housing on the front hub (LF200GY-2). Otherwise the rotation on the dry rubber seal will cause tearing.
Frostbite
Old 08-09-2006, 12:44 PM   #7
Originally Posted by frostbite
Ensure to apply...
Have you been reading the manual? :twisted:
Old 08-09-2006, 02:06 PM   #8
Have you been reading the manual? :Twisted Evil
Manuals? We don't need no stinking manuals....
Frostbite
Old 08-11-2006, 11:23 AM   #9
shadowred   shadowred is offline
Help with Idle speed
wrong forum...my bad
Old 08-18-2006, 07:59 PM   #10
I've updated the DS Prep list with the additions mentioned above.
Keep'em coming....
Frostbite
Old 09-09-2006, 10:29 PM   #11
fashby   fashby is offline
Make sure you grease the swing arm bolt. My Viva GY200 had a grease fitting for this, but it wasn't welded correctly. I had to disassemble the rear suspension to grease it.
Old 09-12-2006, 01:05 PM   #12
Done. Thanks for the tip.
Frostbite
Old 09-15-2006, 04:22 PM   #13
NewEnglandTrails   NewEnglandTrails is offline
Ensure to apply...
I still havent figured out their twisted perversion of the english language in their manuals yet. lol
Old 09-18-2006, 11:27 AM   #14
gyjoe   gyjoe is offline
Tape the electrical connectors together so they cannot pull apart. The problem area on my GY-5 was in the wiring bundle behind the headlight fairing. It is a tight fit to get all the connectors into the protective vinyl boot, and on mine the locking tabs would get pressed and the connectors would come apart. Also on the Lifan GY-5, check the grease seal on the right side of the rear axle. The inside diameter is too large (27mm), allowing dirt to have direct access to the bearing. Others have suggested replacing it with a 25mm inside diameter (size of seal is 25x47x7) and it seems to be the right fit. I had a hard time finding one locally but did get one from bikebandit.com. Lube the cables when you get the bike. I thought my clutch seemed catchy and cheap-feeling until I woke up and lubed it like I should have in the first place. Now it feels and works great. Make sure your headlight fairing is insulated from vibration. Mine had good rubber bushings for the mounting screws on the sides, but the mounting strap on the underside of the fairing was only provided with a rubber washer for the outside and not where the strap attaches on the inside of the fairing, providing a direct route for vibration to the headlight bulb. Some have had problems with headlight life, and this could be one thing that is causing a problem. The rubber chain slider works at first, but mine will be worn through to the mounting screw within the first 500 miles. Start looking for a more wear-and friction resistant material (such as nylon) to replace it with.
2006 Lifan LF200GY-5
Old 09-21-2006, 06:30 PM   #15
My Viva GY200 has a 28x47x7 seal and the shaft measures 25mm.
I found this web site that has many different sizes.
http://www.metricoilseal.com/seal.htm
Called and ordered 25x47x7 oil seal for 9.00 and 7.95 shipping. Kind of expensive, but the part was good quality and even has a tension spring around the seal.
Here is a picture it fit perfectly.
http://www.chinariders.net/gallery2/...g2_itemId=1202
http://www.chinariders.net/gallery2/...g2_itemId=1197
Thanks for the tip! This definitely needs to be replaced. This should be added to the bike prep list.
