Old 12-12-2009, 10:02 PM   #1
Zongshen 200GY-2: 21-inch Front Wheel Conversion
Doing some research to help another forum member, I discovered a 21-inch, front wheel that fits my Zongshen Sierra 200GY-2 motorcycle! Looking at close-up photographs on the Roketa website, it appeared to me the Roketa DB-07A motorcycle used the exact same hub as my Zongshen motorcycle.
http://www.roketa.com/product/7/0/2038.shtml
Roketa also sells motorcycle parts on their website! Therefore, I called Roketa, and I ordered a complete front wheel assembly for the DB-07A motorcycle, part # DB-07A-200-05-65. The Roketa front wheel costs $90, and the shipping charge is $25.
http://www.roketa.com/product/parts_detail.jsp?partId=11634&partName=STEERING%20 ASSEMBLY(5)
After the wheel arrived, I verified the Roketa DB-07A front hub is perfectly compatible with my Zongshen 200GY-2 front hub! However, I also made another, unexpected discovery; the Roketa 21-inch wheel is laced with Lifan 200GY-5 spokes!
I had previously purchased a complete set of 21-inch, Lifan spokes. I had also purchased an extra Zongshen front hub, and a 21-inch, Warp 9 alloy rim. Therefore, I laced the new Warp 9 rim to my Zongshen hub with the Lifan spokes. I then trued the new wheel, and mounted a size 2.75-21, Cheng Shin C858 tire.
Today the temperatures climbed above freezing, so I mounted my new 21-inch tire. Everything fits perfectly, and I am very pleased with the results. However, I plan to wait until the snow melts from the roads before I take my new front wheel for a test ride.
The following photograph shows the 18-inch, Zongshen wheel I removed, juxtaposed with the new, 21-inch wheel. I plan to keep the 18-inch, front wheel so I can switch back and forth from dual sport, to supermoto configurations.
Old 12-12-2009, 10:32 PM   #2
phil   phil is offline
now for the big question is the rear the same as the viva :roll:
halls auto
l
coolster, modcycles, yanmar & zongshen, dealer
fired roketa,lifan and jet moto and apollo quit me who's next
Old 12-12-2009, 10:46 PM   #3
No, the rear wheels are different. If you want an 18-inch, rear wheel on the Zong, you have two choices.
1) You can perform a Yamaha XT225 swingarm conversion.
2) You can lace an 18-inch rim to the Zongshen 200GY-2 rear hub.
Old 12-12-2009, 10:54 PM   #4
Wonderful news, Spud. I'd like to think Zongshen is taking advise from you for their next model. Looks great, and I bet it will perform better off road too. I bet the handling will be different due to geometry changes.
Old 12-12-2009, 11:17 PM   #5
Thank you, Doc! I am back to the original wheel geometry, so I expect the Zong will handle well. The Zong handles very well with 18-inch wheels in both front, and rear. However, I expect the lighter, taller, narrower front tire will lighten the Zong's handling even more. I am now also very pleased to have a much wider choice of front tires. The Shinko 244 is a very good, 50/50 dual sport tire; however, I want a more aggressive tread. I selected the Cheng Shin C858 as my first 21-inch tire, because I think it is a good tire, with a great price. I purchased the Cheng Shin C858 tire for $21, delivered to my front door.
Old 12-13-2009, 06:10 AM   #6
Frog   Frog is offline
This looks great Spud!
I think C858s are very good - they feel a little 'squirrely' on tarmac at first but once worn in they are good on and off-road. I've used them on my 200 and also on a 500 Armstrong.
The 21 front will make a surprisingly large difference off-raod - they just seem to roll over stuff you really notice with an 18.
To me your bike now looks like it should have looked all along - really good work!
Real shame we can not get these in the UK but I have never seen one!
Still I'm enjoying slowly modding my lifan Gy5!
Frog
Old 12-13-2009, 06:53 AM   #7
Originally Posted by Frog
...I think C858s are very good - they feel a little 'squirrely' on tarmac at first but once worn in they are good on and off-road. I've used them on my 200 and also on a 500 Armstrong.
The 21 front will make a surprisingly large difference off-raod - they just seem to roll over stuff you really notice with an 18...
I was considering a number of different tires, but all of them cost two, or even three times as much as the C858! 8O I have read many good reports on the C858 tire, so I could not resist getting a few of them at a cost of $21, delivered.
...To me your bike now looks like it should have looked all along - really good work!...
Thank you, Frog! I am very pleased with the final results; I can't wait to give the new front wheel a good workout! I am very fortunate to have received a lot of excellent advice from many members of this forum.
Old 12-13-2009, 08:14 AM   #8
katoranger's Avatar
Its as close to an xt225 at half the cost now.
Looks like the kickstand is alittle short. Also does the speed read correctly with the new wheel?
Allen
Old 12-13-2009, 01:57 PM   #9
Good point on the kickstand. Looks like Andy's got some welding to do!
Old 12-13-2009, 03:26 PM   #10
Yes, that might be true, Doc!
Old 12-13-2009, 03:38 PM   #11
Originally Posted by katoranger
Its as close to an xt225 at half the cost now…
Yes, I think that’s about right, Allen. However, my YamaZong XT200GY-2 has a few features lacking on the stock, Yamaha XT225: Inverted Forks; LED Turn Signals and Indicator Lights; 4.1 Gallon (Advertised) Clarke Fuel Tank; Fiamm 125 dB Horn; Wide, soft, comfortable touring saddle; FMF Turbine Core 2 Spark Arrestor/Silencer; Extra-Wide Foot Pegs; Heavy-Duty Luggage Rack; and DRC Edge 2, LED Tail Light Assembly. I can also switch front wheels to achieve a supermoto configuration with my Zong. In addition, the Zong is less expensive to repair, and it is not hampered by all the EPA emissions add-ons that make the Yamaha XT225 so cold-blooded. To be fair, however, the Yamaha XT225 is much lighter, has a larger engine, et cetera. Nevertheless, with all factors considered, I prefer my YamaZong XT200GY-2.
…Looks like the kickstand is alittle short…
Yes, as someone warned me, I think the kickstand might now be a little too short. Since it is winter, I have a few months to modify the kickstand before the trails upon up in the spring. I need to do some research, but I think I can install a used, or new Yamaha XT225 kickstand. As Doc predicted, I can also ask my Christian brother Andy to weld an extension onto the Zong kickstand, as shown in the following thread.
http://tw200forum.com/forums/76844/ShowPost.aspx
…Also does the speed read correctly with the new wheel?…
I did a rough calculation, and I figured the new front wheel is about ten percent larger in circumference than the stock front wheel. Since the speedometer was previously ten percent “optimistic,” I predict it should be more accurate after this conversion.
Old 12-13-2009, 04:00 PM   #12
katoranger's Avatar
The speedo was probably originally designed for the 21" wheel.
Old 12-13-2009, 04:13 PM   #13
The following threads contain some more kickstand ideas, Doc.
http://tw200forum.com/forums/74778/ShowPost.aspx
http://tw200forum.com/forums/61530/ShowPost.aspx
http://tw200forum.com/forums/73393/ShowPost.aspx
http://tw200forum.com/forums/84027/ShowPost.aspx
Old 12-13-2009, 04:31 PM   #14
I got a kick out of the baby booty one!
Old 12-13-2009, 04:33 PM   #15
Isn't that cute! I don't think it's my style, however.
