Old 06-16-2009, 06:46 PM   #1
yozalo   yozalo is offline
How do you put the bearing in the back axel?
I just wanted to know what do you use to pound the bearing into the back axel. Should I use a hammer, my bearing shop told me not to use anything made of metal but I am not sure what to use.
Old 06-16-2009, 07:38 PM   #2
katoranger's Avatar
I typically find a socket that is about the same diameter and the tap on it with a hammer.
Allen
Old 06-16-2009, 08:46 PM   #3
I do not have a socket big enough.
Old 06-16-2009, 09:13 PM   #4
Skripo   Skripo is offline
Borrow one. If you hit the center race of the bearing you will chip or damage the ball and ruin the bearing, trust an old R/C helicopter guy on this one, been through many bearings.
You can also heat the axle with a torch, It should expand and allow the bearing to be dropped in.
Old 06-16-2009, 10:02 PM   #5
Are you saying that I should use a socket.
Old 06-16-2009, 10:58 PM   #6
katoranger's Avatar
You could use a block of wood or the handle of a hammer too. Just tap around the sides evenly until it is seated.
Allen
Old 06-16-2009, 11:26 PM   #7
Allen
A block of wood is a safe bet. Yozalo, another way to install bearings is to start with a long piece of threaded rod (often called redi-rod) that will fit loosely inside the bearing. Find some flat washers that will cover most of the surface of the bearings, spin a nut on either side, and slowly tighten the nuts. You'll find that the bearings will eventually be pressed into place without hammering.
Cheers!
Old 06-17-2009, 05:37 PM   #8
Can you provide a picture of the threaded rod either with a stock picture or a picture of your own. Sorry, but I just do not know what you are talking about.
Old 06-17-2009, 05:42 PM   #9
Jim   Jim is offline
It's just a long threaded rod, you should be able to get some at a hardware store..
"Be excellent to each other"
Old 06-19-2009, 12:07 AM   #10
warrior91   warrior91 is offline
Allen
:!: :arrow: 100% (millwright approved :wink: )
'91 Yamaha Warrior- stage 2
'83 Honda ATC 70
'08 Yongjiang 125cc mx (Loncin)
'08 Yongjiang 150cc atv (Jinlong)
Old 06-20-2009, 12:00 AM   #11
Any pressure on the inner race and you scrap the bearing. Get a socket, safest way. You can also us a block of wood if it does not put pressure on the center race.
Old 06-20-2009, 10:57 PM   #12
Thank you guys. I will try doing it with the end of a hammer which id made of wood. I will report back. This forum is very helpful. Also I will be writing a review of the giovanni 110cc after it is fixed.
Old 06-21-2009, 10:26 PM   #13
Ok, I put the bearing in the easily by just using a little wd40 and just using the end of the hammer. The problem was that giovanni sent me the wrong axel which I found out the hard way. Anyways. I've sent them an email.
