Old 06-11-2009, 03:35 PM   #1
Staticworth   Staticworth is offline
Send a message via AIM to Staticworth
My new DB-07a
I just got this about 2 weeks ago. i love it haha
Alright ive got an iridium plug in, exhaust from an older Kawasaki, it sounds so much better than the tin foil stock muffler. Its geared for highway and it cruises. But im looking to do more to get a little more performance, any tip/ideas?
Old 06-12-2009, 01:05 PM   #2
linuxmann   linuxmann is offline
Do you know which front/rear sprocket setup you have?
Old 06-12-2009, 01:21 PM   #3
Stock should be 17/56
Nice machine, BTW!
Old 06-12-2009, 01:40 PM   #4
The front sprocket is still the same but i believe the previous owner but a 42 tooth on the rear.
Old 06-12-2009, 01:58 PM   #5
In that case you are currently geared as high as you can really go, likely too high for some off road use.
Old 06-12-2009, 02:00 PM   #6
If your jetting is on the mark, there is little more you can do from a cost effective/practical point of view to increase performance.
Ride it into the ground and have a great time. :P
Old 06-12-2009, 02:00 PM   #7
yeah, i've taken it off road alot recently and its pretty hard to pull it up to speed i may put a 44 on as i still use it mostly on road. but im really looking for other performance mods aswell, i'm quite new to the bike and im still learning its little quirks haha
Old 06-12-2009, 05:55 PM   #8
SpeedSouth   SpeedSouth is offline
Is the intake side opened up any? Pod filter or hi-flow filter in the box? Airbox drilled out maybe?
I'm not exactly advising these mods, but if you have the exhaust flowing better, the intake could be opened to flow better as well.
Good looking bike! Welcome to the forum.
2008 American Lifan LF200 GY-5 (930 km) - Sold
2007 Kawasaki EX250 - Sold
2006 Kawasaki EX650R - My new ride!
2005 Kawasaki EX250 - A new project
Old 06-12-2009, 06:16 PM   #9
The best gearing combo on/off road comprimise with stock tires looks like 17/45. If you go with the larger off road tires I'd go with a 47-50 rear.
Old 06-12-2009, 11:01 PM   #10
SpeedSouth- its aircooled so im not sure i can do any of those, i could be wrong though.
And yeah i planned on going with larger tires and a bigger sprocket but i dont want to loose highway speeds
Old 06-13-2009, 02:45 PM   #11
katoranger's Avatar
I would agree. The 42 is too tall for off-road and in my opinion almost too tall for street.
Old 06-13-2009, 03:27 PM   #12
Others here have a lot more experience than myself, but I'm pretty sure it being aircooled has nothing to do with how much air your carb is able to intake. We are talking about the amount of air your filter/airbox will allow to pass into the carb.
An aircooled engine simply means it uses the air around it to cool, instead of liquid cooling w/ a radiator.
Since you have a different (assuming better flowing) exhaust, your engine should be capable of moving more air, however, if your air filter is restrictive, you're not really seeing all the gains made possible by your exhaust.
Think of it like a garden hose. A better flowing exhaust is similar to connecting a larger diameter hose to the end. It's bigger and allows more flow, but if the water has to pass through the smaller diameter hose first, you won't get any more water flowing out the larger diameter hose. It is restricted by the smaller hose at the faucet (or the intake, in the case of an engine).
But again, this assumes your new exhaust is better flowing than stock, and may also require rejetting the carb to actually make use of the increase in airflow w/ a little more fuel.
I'm pretty sure you can search and find a few people who have used pod filters on these bikes, or at the very least, people who have drilled extra holes in their airbox.
Hope that helps.
Old 06-14-2009, 01:48 AM   #13
yeah i felt like a serious idiot when i said that about the air filter. I know the exhaust is much better than the stock. Im going to check my air filter tomorrow. I'm not sure how to go about redoing the carb/jet set-up..
Old 06-14-2009, 02:09 AM   #14
Jim   Jim is offline
This video should show you what you need if you want to change a jet.
"Be excellent to each other"
Old 06-14-2009, 09:17 PM   #15
just put MSR low profile bars on and new grips, ill have pictures up soon!
