Old 06-03-2009, 06:29 PM   #1
TurboT   TurboT is offline
GIO Puked
Hey guys..
Started up my QUAD, been sitting in the back yard for a while thought it needed a run. It started okay, I let it run for a bit then tried to give her some gas and it puked. Started up again, idled, when I move the throttle it puked again. Now it won't start.
Think this is a gummed carb or something else?
Gio 110cc Beast, pretty much brand new first tank of gas.
Old 06-03-2009, 06:41 PM   #2
katoranger's Avatar
Sounds like a carb problem. Starving for fuel.
Allen
Old 06-03-2009, 07:30 PM   #3
Think I need to take it for a good 30-45 min burn to warm it up and burn through this old gas. I did get it started again after some hard work.
Old 06-03-2009, 07:34 PM   #4
suprf1y   suprf1y is offline
Sounds like its running too rich on idle. Try adjusting the idle air srew.
Old 06-03-2009, 07:34 PM   #5
katoranger's Avatar
Usually cleaning out the bowl will get any junk that settle into out.
Allen
Old 06-03-2009, 07:50 PM   #6
yozalo   yozalo is offline
Wow, good thing I bought that minkuni carb.
Old 06-04-2009, 07:57 AM   #7
Cal25   Cal25 is offline
Todays gas goes bad pretty quickly. Could give the same symptoms you are haveing.
Old 06-05-2009, 02:49 AM   #8
I actually think it was/is the gas. The gas I had was some year old lawn mower gas I had kicking around here. It's been sitting in there for a while. I do start it up every other day but it hasn't been on a good run to keep things flowing.
It's been hot as well here the past couple days, so the carb may need some tweaking. It does seem to run a bit rich, smells so anyways.
I took it for a spin tonight at dusk around the neighborhood and through some fields. (nobody around) and got 'er warmed up. Seemed to be okay.
I did notice the front wheel seems a little wobbly... nut is tight with pin in it still so perhaps that crap bushing/spacer isn't true. Anyone else have this problem?
