Old 05-07-2009, 07:06 PM   #1
newgio   newgio is offline
giovanni mini hummer swing arm bushing
My sons mini hummer 110cc is 1 month old and the swing arm bushings are shot.Any suggestions or comments on what might fit from a honda yamaha etc would be greatly appreciated.
Old 05-07-2009, 07:08 PM   #2
yozalo   yozalo is offline
Just remove the bearing and go to a local store to find the right bearings.
Old 05-07-2009, 07:23 PM   #3
Re: giovanni mini hummer swing arm bushing
I went to local bearing store and they couldn't find match for bushing.
Old 05-07-2009, 07:34 PM   #4
TurboT   TurboT is offline
What part of the country are you in?
-- I thought these were included in the spare parts they come with?
Old 05-07-2009, 07:52 PM   #5
You can order them from Gio Direct, if all else fails. This is the product you need I assume.
http://www.giobikes.com/Drive-1/Mini...-Arm-Bushings/
Old 05-07-2009, 08:14 PM   #6
The last thing you would want to do is purchase swing arm bushings from Giovanni. They are not good quality and are typical Chinese engineering. It would be better if you go to yellow pages and find a local bearing shop nearby.
Old 05-07-2009, 08:15 PM   #7
giovanni 110cc mini hummer
Thanks for trying to help guys but i was hoping to upgrade these bushings with something superior not simply replacing with same product. There is obviosly a problem when they send you 2 as spare parts and the originals wear out in a month.
Old 05-08-2009, 12:21 AM   #8
I think that's fair, thought about that after I posted the link for the part.
I still don't know what part of the country you're in. I know in my former life I dealt with a lot of bearings (pilot in crankshafts) and also had some weird ones in our machines to fix at times, and we used a company called Cayman Bearings. Also the napa store used to special order them in for us.
If you're in BC I would suggest them but otherwise, as some others have posted a bearing shop should be able to special order some.
...I also did see a Youtube video of some young guy beating on his Gio Hummer and he said he welded something in when his failed. Sounded like a 'farm' repair to me though. JUST WELD IT UP!
Old 05-08-2009, 07:20 AM   #9
forchetto   forchetto is offline
There's a good chance that those bushes are the same as Honda use on some of their small bikes, eg. CG/CB125,CD175, etc. At least the Honda ones would have some decent rubber in them and last a bit longer. Perhaps a Honda spares distributor can help if you take the old ones in.
The generic name for them is "Metalastik bushes" sometimes also spelt "metalastic".
Jincheng Monkey JC50Q-7 (two of them)
Skyteam Dax replica ST110-6 (two of them)
Zongshen ZS125-43
Qingqi QM200GY-BA Super Motard
Yamaha Virago XV1100
Triumph Bonneville SE
Qingqi QM110GY
PGO Bug rider 250 Buggy
