Old 05-05-2009, 06:51 PM   #1
KentuckyDonkey   KentuckyDonkey is offline
Air Blowing Through The Breather?
O-K, guys- while trying to track down why my new Vbike 300 "Monster" (Loncin motor) sounds "clunky" at idle (but great at higher revs), I noticed that there is no filter on the crankcase breather, and that air is continually blowing out of it in a steady pupupupupupupupupupupupup....
Any idears[sic] why this is so? The bike has under 20 miles on it! (And I assume that it was doing this since day one, since the motor has always sounded the same).
Old 05-05-2009, 10:27 PM   #2
warrior91   warrior91 is offline
breather gets rid of excess crankcase pressure...normal...
pupupupup...kinda like the same pupupupup of the piston going up and down??? Funny how that is.
If air is blowing out consistently...why need a filter. dust is not going to go into your engine....it is being forced away from the end of the tube...
Some green freaks have a drip resovior so the 1 whole drop of oil residue can go someplace other than the ground ....
'91 Yamaha Warrior- stage 2
'83 Honda ATC 70
'08 Yongjiang 125cc mx (Loncin)
'08 Yongjiang 150cc atv (Jinlong)
Old 05-05-2009, 10:34 PM   #3
Ah! Thanks for the info. I kinda thought that the breather allowed air to go in, and that that is why most of them have a filter on the end. I know my other bike doesn't have the air blowing out the hose.....and usually on cars, the bnreather is hooked up to the air cleaner...I figured because it was sucking air in. Guess not.
Thanks.
Old 05-05-2009, 10:38 PM   #4
no prob...I hope you have some luck diagnosing "clunky "engine....
Not valve clatter???
'83 Honda ATC 70
Old 05-05-2009, 10:55 PM   #5
Hehe...the valves are a little noisey too- but I hear that that's normal for these engines (?) especially with a quiet exhaust...??
I should know this stuff- I've rebuilt my share of "real" engines....but these small engines have their differences.
Think what I'll do is take the carb off and do a thorough clean and adjust- as that helped my other bike immensley(even though it also is new and shouldn't have needed it); and I'll change out the Chinese spark plug....
Old 05-05-2009, 11:23 PM   #6
Chinese plug...LOL
Mabey that is the noise...You could have a flint and steel inside your engine. (doubtfull though, a flint would have more spark than a chinese plug)
'83 Honda ATC 70
Old 05-05-2009, 11:45 PM   #7
LOL! Bear in mind, that this is the bike that says "Japanese quality" on the Vbike site. Funny, the old <$1300 V4SW came with an NGK plug....but this $2K bike doesn't (nor did it have greasable zerks as pictured/promised)- for some reason, I think Tim at Vbike sent me all his old crap!
Old 05-06-2009, 01:47 AM   #8
I'm sceptical about the validity of NGK plugs in Chinese bikes. Sure, they say NGK, but alot of them are fake. Side by side comparos usually show machining quality and font lettering differences.
