Old 04-30-2009, 02:33 AM   #1
joebrads   joebrads is offline
Up Date got my jtr269.45 today
They sent me both the jtr269.40 and the jtr269.45
Got my Blue threadlocker
got my greese gun for swing arm
Got mobil 1 Synthetic grease for the swing arm Says for Wheel Bearings, Chassis, suspension
got my punch for chain
got new dremel cutting attachment and metal cutter wheels for chain
You thing the grease will be ok for the swing arm
only thing i think lacking is the ring plyers for the clip in sprocket does the needle nose work ok
i think the project will be saturday morning
i tried to bring bike up three flights of step to my back porch didn't work
Old 04-30-2009, 04:34 AM   #2
DDG1976   DDG1976 is offline
Send a message via Yahoo to DDG1976
Bench grinder and a small punch works just as good also.
I have all of soberday to satur up!!
Old 04-30-2009, 11:31 AM   #3
warrior91   warrior91 is offline
Angle grinder and punch, dremel and punch....you might already own a chain breaker...
'91 Yamaha Warrior- stage 2
'83 Honda ATC 70
'08 Yongjiang 125cc mx (Loncin)
'08 Yongjiang 150cc atv (Jinlong)
Old 04-30-2009, 11:54 AM   #4
Measure twice, cut once. I use a dremel, vise, and punch. Easy.
Do you plan on much off road climbing with the 40?
Old 04-30-2009, 06:40 PM   #5
BUG   BUG is offline
In a pinch you could use a file, rusty nail and a rock.
Old 04-30-2009, 08:34 PM   #6
phil   phil is offline
i knew someone had been in my tool box,,,,, Bug
halls auto
l
coolster, modcycles, yanmar & zongshen, dealer
fired roketa,lifan and jet moto and apollo quit me who's next
Old 04-30-2009, 10:06 PM   #7
BUG   BUG is offline
Thanks for the loan, i'll get that stuff back ASAP
Old 05-01-2009, 09:15 AM   #8
katoranger's Avatar
A pair of big snap ring pliers to remove the snap ring on the rear sprocket.
A helper might come in handy too.
I purchase a chain breaker for about $15 someplace. The other methods work too, but the breaker makes it easy.
Allen
Old 05-01-2009, 10:14 AM   #9
Cal25   Cal25 is offline
My snap ring pliers wont quite open up far enough. Ues my needle nose pliers to remove the snap ring and put it back on.
Old 05-01-2009, 10:35 AM   #10
Dragon   Dragon is offline
Is there any concern with the sprocket being too small and rubbing the swingarm pad too hard?
17 and 40 give a ratio of 2.35. I hope you only drive flats.
Chinabikeless
Old 05-01-2009, 11:06 AM   #11
I've heard people reporting that very issue.
Old 05-04-2009, 06:26 PM   #12
Changed order
Ok you guys got me scared so changed order to 269.45. I think you guys helped me make a better choice. TY
Old 05-06-2009, 04:41 AM   #13
If you went from a 46 to a 45 you won't notice much difference. I went from a 46 to a 39, now 5th is just overdrive and it'll run 70 in 4th. I'm also having trans trouble (3rd gear noise) that could be attributed to the lower gear.
Old 05-06-2009, 07:21 AM   #14
BUG   BUG is offline
I could be wrong but i think he started with a 56.
Old 05-06-2009, 02:00 PM   #15
yes i got 56 on it now
