04-09-2009, 07:51 PM | #1 |
My 100CC Lifan won't start
I had to remove the handlebars in my Lifan GY 100and now it won't start. I checked the plug and it's wet. I sprayed it down with brake clean and that didn't do a thing. I just don't think I have any spark, but my spark tester is in my box at work. Any suggestios about what I might try!
04-09-2009, 08:07 PM | #2 |
look at all solder spots on the controls mounted to the handlebars i had a problem with my lf110 i reccomend taking ALL the electrical connectors loose filling them with dielectric or litihum grease and plug them back and use a zip tie to hold them together and you have saved yourself more problems than you realize :wink:
halls auto l coolster, modcycles, yanmar & zongshen, dealer fired roketa,lifan and jet moto and apollo quit me who's next |
04-10-2009, 04:58 PM | #3 |
It's still not starting. I have been playing around with it this aft and it actually fired up one time. Now it seems that it's over fuelling and drowning my plug. I'm really at a loss here. I'm a car mechanic not a bike mechanic. I started this whole ordeal when I went to replace a broken throttle control. Since that oint it's all gone sounth on me. Any ideas?
04-10-2009, 06:55 PM | #4 |
we need to know if its getting fire to the plug but if it fired once and wont again my guess is a fouled plug
04-10-2009, 07:17 PM | #5 |
I agree. What do I do to keep it from fouling? The mixture screw on the carb is about 1/4 turn out. Do I need to look for another coil and new plug? I had it up and running and I shut it off. Now it won't fire at all. This is getting to be frustrating. I have cleaned the carb and found that one jet had an obstruction. I cleand the orifices with a torch tip cleaner. Thats all I have done and now I can't seem to make it purr again. HELP!
04-10-2009, 07:32 PM | #6 |
the factory plugs on most are a brand called torch they are so proud of them they dont have the brand on them go to a ngk or better a ngk IR once a plug gets wet its almost always forever gone i think youll be fine once you get the new plug and run it some
04-10-2009, 08:40 PM | #7 |
What about the carb set? I bottomed out the mixture screw and turned it out 1/4 turn. Is this too lean or should I leave it be?
04-10-2009, 08:43 PM | #8 |
Sounds a little lean; try 1.5 turns out to be safe.
04-10-2009, 11:25 PM | #9 | |
'91 Yamaha Warrior- stage 2 '83 Honda ATC 70 '08 Yongjiang 125cc mx (Loncin) '08 Yongjiang 150cc atv (Jinlong) |
04-10-2009, 11:26 PM | #10 | |
The kill switch is a place to look as well...it must be looped , not disconected, if your bike is also equipped with a keyswitch. I have found the connections are light wire and poorly crimped. With your bar removal project you might have pulled a connection apart without knowing...
04-11-2009, 02:07 PM | #11 | ||
04-11-2009, 08:12 PM | #12 |
How do I go about dropping the needle a notch?
*EDIT* I got it figured out without a problem. It was very easy. I just unscrewed the top of the carb, removed the slide, removed the "hairpin" and pulled the needle. Then I removed the e-clip and moved it up 2 notches. ^the reason I wrote this out was so anyone who's never done this before would have a clue and not be scared to do it on their own. The bike is running great now and I'm very proud that I was able to do it myself (with some good help from China Riders) Thanks Phil |
05-12-2009, 01:53 AM | #13 |
HELLO , did you move the clip up 2 notches because it was over fueling?? and now it is beter.. not over fueling... right??
05-12-2009, 08:38 PM | #14 |
It made a difference, but I ended up swapping out the carb for a Mikuni 25mm. That carb really makes the bike run well.
