Old 03-15-2009, 02:13 AM   #1
FastGM400   FastGM400 is offline
Baja\Viva 250cc Battery\Fork Oil Questions
Baja X250 or Similar. (Viva 250)
FORK OIL
I need to know how much more to put in and not blow out the seals. If I drain it and replace it with Yamaha fork oil would it be better at the same amount that was filled from factory?
BATTERY
I need to find a better battery, the one I have is a CTLX7L-BX is toasted and can't find out where to find cross references.
Old 03-15-2009, 03:41 PM   #2
katoranger's Avatar
I would drain the oil into a measuring cup and then replace with the same amount.
The battery you may need to take someplace and match it up.
Allen
Old 03-15-2009, 05:39 PM   #3
AZ200cc   AZ200cc is offline
try looking at a ytx7bs Yuasa battery...Should be the same.
