Old 02-08-2009, 04:04 PM   #1
Dragon   Dragon is offline
Swing arm joint free play
The joint on the swing arm moves up/down and left/right, besides rotating. The freeplay isn't much; but it's definitely noticeable. Is this something I need to worry about? I ride it on the freeway almost everyday; so I'd like to know if the wheel is about to fall off!
Chinabikeless
Old 02-08-2009, 04:08 PM   #2
liverchip   liverchip is offline
Send a message via MSN to liverchip
Check the bushings as well as the swingarm pivot points on the frame.
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 02-08-2009, 04:41 PM   #3
A close thorough inspection will tell you if the wheel is ready to drop off.
I'd look into it to make sure it is all right before hitting the road.
I wonder what would happen first if it came apart........well I suppose it would first get a bit wobbly like a flat tire maybe or just dog track a bit.
Old 02-08-2009, 09:26 PM   #4
The pivot bolt was loose. I tightened it, but there's still some freeplay. I guess that means the bushing is worn-out. Where do I find a new bushing?
Chinabikeless
Old 02-10-2009, 05:37 AM   #5
czowner   czowner is offline
I found some "top hat" bronze bushes at my local bearing supplier. The bushes are not an "off the shelf" size I had to buy larger ones and have them machined down, and a new sleeve made for the middle. While it was all in bits I put some bronze bushes and grease nipples in the shock linkage as well.
Jonathan.
Old 08-31-2014, 09:55 PM   #6
Lucien   Lucien is offline
Lucien's Avatar
Thanks for the info!!!
Old 08-31-2014, 10:31 PM   #7
Where in Baja are you? I am seriously thinking of riding to Ensenada in November to watch the start of the Baja 1000. Also, next March for the start of the 250 in San Felipe.
Old 09-01-2014, 12:47 PM   #8
Lucien's Avatar
I live in Tijuana, culcune let me know, maybe we can work something out!!
Old 09-01-2014, 06:59 PM   #9
Do you ever ride east, maybe to Mexicali? I would like to try a ride there one of these Saturdays. Algondones and San Luis are right next door to me if you ever get out this way, too. Tijuana sounds like it would be a weekend ride for me, but that crossing seems like it would be a monster--maybe cross at Tecate or even Algodones coming home. I guess I have hijacked this thread long enough--PM me!
Before I go, is anyone else up to try to watch the start of the Baja 1000 this November, or even the Baja 250? We can ride from Yuma or I could meet up with you between Yuma and there...
Old 09-03-2014, 09:28 AM   #10
Lucien's Avatar
Here in TJ, if you ride, if your bike is not too bulky, you slice lanes at the border...
