Old 09-04-2008, 11:24 AM   #1
Dragon   Dragon is offline
E-starter don't work when in Neutral
The E-starter don't work when the transmission is in Neutral.
If I put the transmission in first-gear, the E-starter miraculously works.
What's up with that?
Chinabikeless
Old 09-04-2008, 11:43 AM   #2
alonzo   alonzo is offline
wow! that is quite the freaky ordeal. by chance will it start if the kickstand is up and bike is in Neutral?
Is this a new problem? or have you had this since you got the bike?
Old 09-04-2008, 11:46 AM   #3
It's a new problem.
My bike does not have a kick stand switch.
Chinabikeless
Old 09-04-2008, 12:42 PM   #4
sarw15   sarw15 is offline
Had this same problem on a old honda the Neutral switch is ether out of adjustment or has failed. on the old bike it had failed and was told that when the bike was in Neutral no go but place in gear and then the switch is bypassed to the clutch saftey switch. My problem was back then I had to remove the side cover to replace it and had no clue what I was doing so I just would always pull the clutch in last two years
Larry 2008 Roketa RKM-200E5, 200cc
Old 09-04-2008, 02:30 PM   #5
Jim   Jim is offline
I think this has to do with the diode, it should be behind the headlight somewhere..
"Be excellent to each other"
Old 09-04-2008, 06:30 PM   #6
Guest
Posts: n/a
Guess who ??
