Old 08-07-2008, 09:12 PM   #1
08obpwrx   08obpwrx is offline
HI-BIRD 250 Help me please...
I've been looking all over for this... the valve cover for the hi-bird 250. It cracked on me the other day and bike just sputters. I JB welded it and that lasted about 20min... The cap is 33mm across and i need to find a new one asap. Called Vbike and tim was no help. amacycle will not let me talk to parts?! Please help, haven't been able to drive for over 2 weeks
Old 08-07-2008, 10:28 PM   #2
Sorry that mine were 30mm. Have you talked to Bruce at EJcycles? Kato has his phone #. Give "Im easy" a pm too. If they can't help, ask them who might help?
IronFist
The "chain" of command is used for beating spammers.
Old 08-07-2008, 10:36 PM   #3
^^ Thank you for your help
Old 08-08-2008, 12:21 AM   #4
ImEazy   ImEazy is offline
Maybe this?
http://www.scooterparts4less.com/web...roke_Bolts.htm
4-Stroke Cam/valve Cover
2000 MZ Baghira
Old 08-08-2008, 08:16 AM   #5
Ask them to measure for 33mm fitment. Also count and measure the threads. The correct size is important but the cap has to screw in, #threads/ inch?
IronFist
Old 08-08-2008, 08:18 AM   #6
katoranger's Avatar
I would give one of those a try.
I successfully JB weld my oil screen cap. No leaks and it has been a week.
Allen
Old 08-08-2008, 08:54 AM   #7
I JB'd a valve cap, not as badly mashed as 08obpwrx's. My cap's rubber O rings were shot and the caps was over tightened to compensate for the flattened o rings. When I got my new caps I got new rings. When I tightened them I didn't over wrench them. The caps are thinner than I thought, the metal is SOFT. Valves must be checked through out the life of the bike, so... Let the rubber ring make the seal to the motor, I won't over tighten mine. That's not to say that when you get a bike, the last guy didn't over tighten them. Good luck, 08obpwrx.
Old 08-08-2008, 09:20 AM   #8
alonzo   alonzo is offline
you might try a hydralic supply store, or napa auto parts. I bet if napa dosent have it they can order it.
you also said the bike just sputters? I do not think the cap will cause this. recheck your tappets fuel ect.
Old 08-08-2008, 12:22 PM   #9
Allen
Funny, my oil cap is cracked even worse... and leaking, i must have over tighened it too :(
Old 08-08-2008, 12:30 PM   #10
I think you might be over tightening ???????
IronFist
Old 08-08-2008, 01:41 PM   #11
katoranger's Avatar
Must be over tightening. All that is needed is a snug fit. I gave mine alittle too much and cracked it.
Also with the JB weld you need to clean the part really well and then give it some time to harden. Even with the JB kwik the longer you wait the better.
Allen
