Old 08-04-2008, 09:10 PM   #1
joeyo25   joeyo25 is offline
Tire options
edit
It'll stop hurting when the pain goes away!
Old 08-04-2008, 09:15 PM   #2
katoranger's Avatar
It seems that alot of tires are out of stock, but here is a rear. The 110/80-18 is close to the 4.10-18 rear.
http://www.americanmototire.com/cata...th=200_239_242
The duro medians are still out of stock.
Allen
Old 08-04-2008, 09:23 PM   #3
alonzo   alonzo is offline
support your local bike shop! take the machine down there and get some advice on the tires. If they are making money they dont care where the bike was made china, japan,,,,,, middle earth tires are tires.
Old 08-05-2008, 05:17 AM   #4
tigertamer   tigertamer is offline
Re: Tire options
Originally Posted by joeyo25
Thanks in advance for any help and advance forgiveness for any neccessary newbie flaming!
joeyo25
But Joeyo25, You would actually be worthy of the "Super Cool Boy" flaming
Now it's back to my own "pay grade",
Tigertamer
07 H-D XL883C
06 LF 200GY-5
Yin and Yang
CAUTION
Obey The Traffic Regulation.
Always Wear a Helmet.
Don't Ride After Drinking Wine.
Before Operation, Read The Owners Manual Carefully.
Old 08-05-2008, 12:54 PM   #5
I think Kato has your back with the tires.
As far as, "forgiveness for any neccessary newbie flaming! "
If there is any Newbie flaming on the site, please PM me, even if it's on someone else, thanks.
I've got yer back there :wink:
IronFist
The "chain" of command is used for beating spammers.
Old 08-05-2008, 01:26 PM   #6
katoranger's Avatar
Better answer to your question.
A 4.10x18 equates to about a 110/90 metric size and a 2.75x21 to a 70/90x21 tire.
I have been told that a 120 wide rear street tread will fit.
I am also running a 90/90 front tire since that was the only option for a 21" wheel in the duro median tire.
If you don't want to mount them yourself just go down to a local shop and have it done.
The kenda challenger is a got street tire that comes in the right sizes.
http://www.americanmototire.com/cata...ath=33_155_157
Allen
Old 08-05-2008, 09:02 PM   #7
duck   duck is offline
A 120/90-18 as shown on the parts list will fit...barely. I had to move my exhaust out a little to the side to clear, and a battery box relocation is a good move at the same time.
It's a pretty big gear ratio change so unless you are looking for more top end you might wanna pick up a larger rear sprocket to go with that tire.
-Duck
Allen
-Duck&nbsp;<br />07 FJR1300<br />06 QH200GY Hi-Bird&nbsp;<br />86 Rebel 250&nbsp;<br />86 MB5&nbsp;<br />72 GT550<br /><br />
Old 08-05-2008, 09:05 PM   #8
katoranger's Avatar
The 110 is much closer to stock size and you will not need to worry about clearance problems.
Allen
Old 08-05-2008, 09:17 PM   #9
I found, bought, and used 21" and 18" Kenda challenger street tires on my chinabike. I liked them a lot.
IronFist
Old 08-05-2008, 09:45 PM   #10
Jim   Jim is offline
What about the cheng shin barracuda, http://www.americanmototire.com/cata...cPath=33_96_99
I was thinking of getting some of these for my gy6...
CHENG SHIN BARRACUDA 3.00H-21 FRONT $28.74
CHENG SHIN BARRACUDA 110/90H-18 REAR $41.41
C926 FRONT/C915 REAR BIAS PLY TIRES
SPORT TOURING
H-RATED UP TO 130 MPH
BLACKWALL; TUBELESS
CIRCUMFERENTIAL GROOVE ENHANCES WET GRIP
DIAGONAL GROOVES PROVIDE GREATER WATER DISPERSION FOR IMPROVED WET-ROAD CONFIDENCE
ADVANCED CARCASS CONSTRUCTION PROVIDES EXCELLENT HANDLING AND STABILITY ACROSS A RANGE OF SPEEDS
COMPOUNDED FOR MAXIMUM MILEAGE
Though it is tubeless, I'm not an expert, will they possibly work with a tube, or are those challenger's a better idea since they specifically say tube/tubeless?
"Be excellent to each other"
Old 08-05-2008, 09:52 PM   #11
katoranger's Avatar
You can run a tube in a tubeless tire with no problems. Just not the other way around.
Allen
Old 08-05-2008, 11:33 PM   #12
Jim   Jim is offline
Thanks Allen, that's what I was figuring, but I wanted to double check before ordering... I think those sizes look right for my bike....
I found a few pages with info on tire size conversions
http://www.webbikeworld.com/Motorcyc.../tire-data.htm
http://www.steelthundercc.com/tiresizes.html
My gy6 should have
front: 2.75/21
rear: 4.1/18
so for the rear I should go 110/90 - 18 and the front should be I think 80/90 or 90/90 - 21, but with the 21 barracuda, I only see the 3.0 -21 so I am thinking it will be my only choice with that brand... Is that going to make that tire wider, or taller?
Thanks again.
Old 08-06-2008, 08:25 AM   #13
katoranger's Avatar
I have 3.0 tire on the front of my bike. It is fine. I would use a 110/90 for a rear also.
I have a kenda challenger that I salvaged form a yamaha that is going on next.
The barracudas are fine too. Low-cost tire in the right size. The street tires will last forever on these lightweight bikes.
Allen
Old 08-06-2008, 08:49 AM   #14
Wool-Z   Wool-Z is offline
those Barracuda's came on my Sierra. Handle good ride smooth, on the street that is. Watch it in wet grass. Work with tubes.
Old 08-06-2008, 10:56 AM   #15
Jim   Jim is offline
Thanks Allen, and thanks Wool-Z....
Is the 3.0 taller, or wider, or both?
