Old 06-23-2008, 03:43 AM   #1
MauiSurfer   MauiSurfer is offline
HID light installation, $20 spent used ebay light.
Go see pictures in my gallery of my 'success?' at installing a HID light. Total spent $20 on ebay used light and 1 toggle switch.
I tried running off the headlight wiring and there wasn't enough amps to power it - the headlight would blink.
So in my next attempt, rather than spring for a relay and all the extra wiring, I wired it directly to the battery and wired an inline cheap toggle switch mounted on side panel next to the battery. This worked, no blinking, and has the added bonus of keeping all the stock lighting legal. The downside is that you have a rather difficult switch to reach while riding, but I got used to it already.
http://chinariders.net/gallery2/main...avId=x83d3a5c3
Old 06-23-2008, 03:09 PM   #2
I don't know if this helps, but
cb 350's are known for being weak at generating electicity.
ebay cb350...it has a conversion hid kit that uses stock wiring, and the stock bulb mounting position. Looks like it would fit in the center hole of your light. I think its 25/35w??? Not much anyway. Bit pricy , very low wattage.
Like I said, I don't know if this helps
IronFist
The "chain" of command is used for beating spammers.
Old 06-28-2008, 05:49 PM   #3
jayg   jayg is offline
Maui are you still running the stock light with the HID?
Old 07-07-2008, 03:22 AM   #4
Yes, it's still running fine, no problem with the heat but the left/right direction of the light could be a little better. Since it was mounted to the left of the reflector, it shoots a bit right. I guess that's good in that it doesn't blind the drivers but if I had to do it again I would switch the positions of the stock bulb and the HID bulb.
Old 07-07-2008, 07:43 AM   #5
kczukiman   kczukiman is offline
Wow thats a big difference.I think I will do that as well.
Kman
2007 HI-BIRD 250
2007 Vbike V4S 250
Old 07-07-2008, 09:45 PM   #6
maf119l   maf119l is offline
Send a message via Yahoo to maf119l
Is the HID high and low beam or just high?
yamaha vstar 650,unknown chinese 4 wheeler,johnny pag 250 spyder,lifan gy-5
Old 07-24-2008, 01:48 AM   #7
Just a very high beam, that's why I left the stock bulb in there so I can have a low beam. (and a medium and a high!)
Old 08-01-2008, 02:51 PM   #8
partsdude   partsdude is offline
Great Job & great pics, Thanks. I'm going to look into that conversion for my upcoming build.
1970 CT 70 - 1975 RD350 - 1977 KE100 - 1979 FL250 ODYSSEY - 1999 VSTAR650 CLASSIC - 2001 VSTAR 1100 CLASSIC - 2007 ? SAGA GY250 ?
