Old 06-08-2008, 08:24 PM   #1
panamarandy   panamarandy is offline
Send a message via Yahoo to panamarandy
Stator on chinabike
has anyone had any experience in changing out the stator. I have the 250cc Tank Vision R3 and keep burning out the CDI unit. And have been told its because the stator is going bad.
Thinking about changing it myself if its not to much work..
2007 Tank Vision R-3
2005 Quinqi Scooter
Old 06-08-2008, 11:46 PM   #2
DesertDog   DesertDog is offline
easy ... does it.. there panama
no really its easy once u've messed up on acouple of them lol
is yours oil cooled ? if not just remove the side casing and go from there,
mine are oil cooled so i have to drain the oil first to do that...
it will be tightend down to the side casing by a center nut or a very large bolt
if you have the new one already it wont take long to change it out
good luck
DD
DesertDog
Old 06-09-2008, 01:55 AM   #3
kens97sto171   kens97sto171 is offline
Kinda along this topic... Does anybody make a high output stator for a 2006 Roketa DB07 200cc OHC engine.
I am running without the battery right now, and the lights dim when I put on the brake or turn signals.
Thanks..
Ken
Old 06-09-2008, 06:15 AM   #4
dr1445   dr1445 is offline
i think that "baja designs" will wind up a special coil, the cost, well that's another matter.
Old 06-09-2008, 11:10 AM   #5
Thanks..
Ken
thats probly a good way to burn up a stator real quick,
no different than a care alternator, you can run a car with no battery once u jump it and then it will run without a batt. , but will burn up the alt. , because it thinks it is needing to charge all the time and nothing to charge
so i cant imagine it would be different for a bike
DesertDog
Old 06-09-2008, 11:13 AM   #6
katoranger's Avatar
You need a to pull the stator cover off and the remove the few screws that hold it to the cover. Put in new stator and replace cover.
It may take you an hour.
There are articles and winding your own high output stator out there too.
I have seen ones listed for XRs and ATCs that may interchange.
Allen
Old 06-09-2008, 09:31 PM   #7
olds_cool   olds_cool is offline
Once you're done, Randy...dump the bike! It's seem to be a big headache. Like I mentioned before in another thread, I got most of the kinks worked out. I'm still planning on getting another bike, though.
Nuff said!
olds_cool
DON'T BE A SQUIDIOT! 8)
Old 06-10-2008, 10:57 PM   #8
Its running again.......
2005 Quinqi Scooter
Old 06-11-2008, 01:04 AM   #9
To me it sounds like a regulator issue.
IronFist
The "chain" of command is used for beating spammers.
Old 06-11-2008, 03:31 PM   #10
Yes, I had already replaced the regulator/rectifier when it happened the first time, didnt seem to make a difference.
So beats me.........
2005 Quinqi Scooter
