Old 05-18-2024, 05:33 AM   #1
Plutso   Plutso is offline
No electricity - HSUN 400 ATV year 2008 - copy of Yamaha Raptor 350
Fault reason in my previous post https://www.chinariders.net/showthread.php?t=34037 was that cdi was damaged. After installing new cdi, the ATV worked as brand new
But unfortunately the fun was very short. After first ride (ca 2 hours) the electricity disappeared, as you can see here: https://photos.app.goo.gl/Ds2RG4sQUHtoB3zf7
I found one a little bit damaged cable, but I'm not sure, that it is the main reason.
Picture of cable: https://photos.app.goo.gl/xF4oxS8ez8m9bST56
Also I found, that ATV has two fuse socket, but one was empty. The one in use has fuse 30A. I put same (30A) brand new fuse to the other socket also, but no results, no any electricity.
Pictures of fuses and sockets are here: https://photos.app.goo.gl/8GfZaMrsQbzDf6jp9
Does anyone have any ideas what could be wrong?
Old 05-18-2024, 08:51 AM   #2
dugndeep   dugndeep is offline
I'm no mechanic so all I can say is go back and check your repair to check for loose wire or connections.
Old 05-19-2024, 02:59 PM   #3
Yes, I checked again and found that ignition interlock was damaged. I temporarily replaced it with a table lamp switch , until the right ignition lock arrives.
Old Today, 09:48 AM   #4
on the road again......lol
