11-30-2023, 08:47 PM | #1 |
Bashan Storm 250 Rear Wheel Hub
So I busted my rear wheel hub. Is there any chance that I could fix it or should I just replace it all together and if I replace it what would work or where can I buy one?
https://imgur.com/y1tLmZi |
12-01-2023, 10:11 AM | #3 |
This will be your best option. The Brozz is a Bashan, so might be an exact match.
12-01-2023, 10:36 AM | #4 |
Maybe the rear cushion assembly ($25)
No 8 --Rear Cushion assembly product # BZCA8 https://shop.brozz250.com/eshopprod_...ear_Wheels.htm
12-01-2023, 06:00 PM | #7 |
I have no clue how that rear hub broke. I was just riding it one day on the street after patching my front tire and next thing I knew my chain flew off and the sprocket popped off. Thankfully I was only going like 8MPH. Rolled the beast home and noticed the crack.
12-01-2023, 06:56 PM | #8 |
There is a chip of the cast missing (the hole). It looks like a rock hit it? Or maybe the chain? A flinging chain has momentum, and could do that.
Or, the chain could bind, and twist or brake (stop) the sprocket HARD.
12-02-2023, 03:10 PM | #9 |
That chip only appeared after I touched the area. It just cracked under my finger. I have a suspicion that a rock hit it considering where I rode it was kinda rocky.
